Solution Title:
How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S
Resolution/
Solution
Fixed!
Did not fix.
Resolution Role: Fix
Critical Message: The
Envelope must be placed in the Bypass Tray face down (flap side up) and
Long Edge IN.
In Microsoft Word (Word 2000)
Under the Tools tab, select Envelopes and Labels.
Enter your Delivery and Return addresses.
Click on Options
Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
Under Printing Options, select Portrait (LEF) - Long Edge Feed
As Feed from, select Tray 5 (Bypass)
Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
Under the Paper/Output tab
Set the following features as follow:
- Job Type: Normal Print
- Paper Size: COM10
- Output Size: Same as Paper Size
- Image orientation: Portrait
- Image Rotation: OFF
- 2 sided Print: 1 sided Print
- Stapling: None
- Output destination: Center Output Tray
- Offset Stacking: None
- Set Paper Source to Tray 5 (Bypass)
- Click on Bypass Tray Settings
- Paper Type: Heavyweight (1 or 2)
- Feed orientation: Portrait
- Click <OK>
- " on Specify Paper Type and select Heavyweight (1 or 2)
- " (Apply> and <OK>
- " <OK> again
In Microsoft Word under
Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing
envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0
312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
when i push the function button it says cassette out of order - does it just need a neww cassette or overall service
