Question about Philips 46PP9302 46" Rear Projection Television
Philips Projection model #51PP9303H17 AV5 input not working?
On my model I am trying to hook-up my HD player using my DVI port at input AV5. The problem is that while scrolling thru my channels, there is no AV5. AV1-4 are listed. I contacted Philips but al they could do is refer me to local technician and I would have to pay for his services. Can anyone help with this? I've tried everything I can think of.
  • dataman62 Dec 09, 2007
    I have the same problem. No AV5 on the channel list. I tried connecting an HDD DVD player with a Philips HDMI to DVI converter cable, but no luck. AV5 did not appear, even after pulling the power plug to reset the channel list. I called Philips tech support, but they weren't able to provide a solution.
After many hours of research, I was able to fix the missing AV5 channel. I had to access the service menu using code 062596 and the Status/Info button on the Philips remote. There was an error message that had to be cleared and then AV5 needed to be turned on in the options menu. While I was in there, I also turned on the WSCR option, giving me two additional wide screen aspect settings that had also disappeared. I advise you not to go into the service menu unless you do your homework and document each setting before you make changes. Good Luck!
Posted on Dec 09, 2007
Philips 20pf5120/28 Calibration for gaming using DVI Input
lololol HD to standard video - standard video back to HD is going to cause some issues. Go straight HD to HD with a hdmi to dvi instead. Even if your tv cant do HD theres a loss of information and signal for every adapter you put in and the length of the cord.
Dec 25, 2014 | Philips Televison & Video
Philips projection dvi problem
The set is old enough (based on model number indicated here) the DVI input (supprised it has one) it will not work with newer equipment.
Apr 15, 2012 | Philips 55PW9363 55" Rear Projection...
55" Philips rear projection HDTV..
that input is called DVI digital video interface it is only for video. there should be some red and white composite input jacks for the audio near the DVI connector. you will need to hookup the red and white cables from the tv to the cable box or dvd player or whatver you are using. good luck
Jan 06, 2011 | Philips 55PW9363 55" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Hdmi cable connection
Your model has a DVI input which is at the top of component 1 section on the rear panel which is for HD input or you can use the RCA plug ins for HD inputs on the component 1 section as well. Either will allo HD to be hooked to your set.
Jan 04, 2010 | Hitachi 51S700 51" Rear Projection...
I have an DVI to HDMI cable running to my Playstation 3. The playstation reconizies the connection. When I search the tv for the connection I connot find it.. The back of the tv says the DVI input is...
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Dec 03, 2009 | Philips 51PP9100D 51 in. Television
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Hooking up from hd receiver to hdtv ready projection tv. what cables do I use? vga or rca component red, blue, green and sync white/black? My hd receiver has output of :hdmi, rca component, s-video ,...
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Mar 07, 2009 | Philips 60PP9202 60" Rear Projection...
Trying to find a port for sound input on Philips DVI LCD TV.
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
Feb 22, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
No av5 in menu
it becomes visible after you hook up a dvi to hdmi adapter
Jan 01, 2008 | Philips 51PW9363 51" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
