Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips HDTV My Philips tube HDTV will not turn on it will make the static sound of it starting up and then the green led wil then turn red and it will not do anything.
    President:
  • 4,402 Answers
Most common problem is convergance ic's
when the red light blinks how many times short blinks and long blinks.
Posted on Dec 14, 2007
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bulb Replacement
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Apr 17, 2009 | Philips 60PP9753 60" Rear Projection...
Philips Plasma NO LIFE
Are all the caps good on the PSB.? Most sets have Samy boards and they used very shotty capacitors. Some show NO visual clues of being blown as in poped at the (X) top. They just vaporize/dry out. Do you have a cap tester?
Best Regards and Semper Fi
Feb 08, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Philips 42fd9954-175
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
May 13, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Picture turned green
It sound like a bad tube there are three tubes red green and blue.
i suspect the blue tube is bad. tubes cost 160.00 plus labor 450.total . sometimes the tubes
can be fixed or the tv tech can adjust the screen voltage on the tube.
good luck thanks jay leadingedgeelectronics.com
Apr 29, 2008 | Philips 60PP9202 60" Rear Projection...
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Dec 21, 2007 | Philips 42HF7444T 42 in. Plasma TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
