Home | Canon | PIXMA MP150 All-In-One InkJet Printer | Canon PIXMA MP150
Canon PIXMA MP150 All-In-One InkJet Printer
Problem for Canon PIXMA MP150 All-In-One InkJet Printer
Canon PIXMA MP150
By ruth11 on Nov 29, 2007
I am receiving an "E3" Paper Jam error code, and can't get my printer to work. Any idea as to how to fix it? (There is no paper jammed in the printer).
Thank you!
Comments:
Nov 29, 2007
- Thank you! I tried turning the power off, unplugging it, etc., etc., but that didn't work. I will try looking into the printer with a flashlight tomorrow. Thanks for the info, and for providing the tech support #.
Sponsored Links
Same Problem
Dec 05, 2007
-   Same shit here, a4 paper feeding was jamming but printing for smaller photo paper worked ok.
unplugged wires, printer up-side down and got very small part (external object) out of the paper feeder.
Now it works ok again. Thanks man for advice. I love my kids ;)
-   jasu2005
Dec 02, 2007
-   Hi, I had exactly the same error today - Paper jam! But there is no paper in the printer. And same exact thing that jmcarr had happen to me. I also did find a "black twisty wire" stucked to the roller where we drop the paper. Now my printer is back to normal again. Thankfully, I read this website and all your comments. Thank you guys!-   mausy
Nov 29, 2007
-   hi,my name is shelley,,when i turn my printer on it has E 3 and the alarm light is on,,can you please help me find out what i can do,,,my kids really need it,,thank you so much
-   tim hortons
Best Solution
posted on Feb 13, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Had the same problem. Fixed it by turning the printer upside down and out fell a 25mm screw. Sorted now.
Solution #2
posted on Nov 29, 2007
Helpful)
jmcarr
Rank: Apprentice
Rating: 88%, 5 votes
I had the same error that started last night! There was no paper jammed, but after several hours of trying to get it to work, I did find a black twisty tie stuck on the roller and that was causing the problem (I have no idea where that came from!) If you are sure there is no debris or foriegn objects stuck in there somewhere, just try resetting the machine. Turn the power off, unplug it from the power source and remove the USB cable if it is connected to a computer. Then plug it back in and turn it back on. Press the start button (black or color) and hopefully that clears it. If not, look again for something stuck in the paper feed tray, also lift up the cover and look in there with a flashlight - to see if anything is wedged in there. If that still does not fix it, try calling the Canon tech support line - 1-800-828-4040. I hope you're able to get your printer working again. Good luck.
Was this helpful?
Yes
No
Solution #3
posted on Jul 04, 2009
Not Rated)
tripathi_swa
Rank: Apprentice
Rating: 0%, 0 votes
HEYY GUYS MY PAPER HAD NT CAME OUT YET I HAD TRIED ALL THE THINGS WHICH U ALL SAID BUT STILL ITS STUCKED WHAT TO DO NOW........AND MY PRITER'S INK IS ALSO FINISHED N I THINK THAT THE PAPER INSIDE IT IS NT STRAIGHT WHAT TO DO GUYS TELL ME FAST!
Was this helpful?
Yes
No
Solution #4
posted on May 05, 2009
Not Rated)
palcando
Rank: Guide
Rating: 81%, 4 votes
This same prolem has plagued many with the MP150 cannon printer, Here's what I did to fix this...E3 code shown in window
when no actual paper jam could be viewed ! I did the restart thing
by turning the printer OFF and waited (10) seconds or more, then
when I turned it back on...I listened to here the feed rollers turning
and forced feed a sheet of paper into the feed rollers..and sure enough OUT CAME a small piece of paper..actually a small strip of glossy paper like a strip that might be attached to a part during manufactureing..any way that paper has printing on it, it says;
(nitto No.500) it would be interesting to know if others out there
find the same piece of paper !! Give this fix a try. Palcando.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP150 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP150 All-In-One
Do you recommend Canon PIXMA MP150 All-In-One InkJet Printer?
Answer
Answer
i have a new computer with windows 7 and i can't install the driver of my printer canon pixma... (More)
Answer
my canon pixma mp 150 scanner doesn`t work and there is amessage says that it isnt connected but... (More)
Answer
no paper in it, but it says jamed paper ,can't see any problems
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA MP150 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 418
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
