Question about HP LaserJet 3300 All-In-One Printer
Laser Jet 3300
It makes constant noise like the scanner is adjusting. It will not stop. What should I do?
  • arunwai Jan 28, 2008
    i have the same prob with my LJ3330 mfp...after some time the noise stops and display gives the "scanner error, swtich off & on". after switching on it went ok for some time and same problm started. btw, what's "scanner lock"?
  • rajesh hada Feb 13, 2008
    when i on printre stuct in scener warming then nothing go after this problem please give me way
  • 56 Answers
Hi, when you lift the cover where the flatbed glass is can you see the scanner trying to move back and forth? Also you might want to check and make sure the scanner lock didn't get moved to where the scanner just goes back in forth ? Are you getting any error codes?
Posted on Dec 04, 2007
SOURCE:
How do I scan on the Canon imageRUNNER 3300
instalation of photocopier/scanner with pc model no IR-3300. Kindly tell me the procedure to install it and make it functioning...
Mar 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Which scanner software i should install on my PC for IR3300
Install the driver for the scanner model and use any software that supports scanning via TWAIN or WIA like photoshop, imaging or paint shop pro.
Oct 28, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Hp laser jet 1020 printed blank. toner, scanner ok
laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Jun 23, 2009 | Office Equipment & Supplies
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Nov 26, 2008 | HP LaserJet 1200 Printer
Info
Canon ir3300 is a black and white 33 ppm (A4) copier , printer (network), fax and scanner ( b/w).
For more info please visit canon website.
Sep 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
HP LASER JET 3330
Sounds like the scanner bulb mate. There is a post on here already about how to fix the scanner bulb problem.
Hope you fix it
Apr 05, 2008 | HP LaserJet 3330 All-In-One Printer
HP Laser Jet 3300 constant noise
I had the same problem. After updating a hp firmware, so far so good. The noise is gone.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=66367&prodTypeId=18972&prodSeriesId
=66359&swLang=8&taskId=135&swEnvOID=54
That is the link for the 3330. It is under the downloads section and is at the bottom. They refer to it as firmware
Nov 08, 2007 | HP LaserJet 3300 All-In-One Printer
HP LaserJet 3300 All-In-One Printer Logo
220 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
