Question about Akai LCT4216 42 in. LCD Television
LINES ON MY LCD 42" AKAI TV
HELLO. JUST GOT MY TV TODAY...HOOKED S-CABLE AND OTHER CONNECTIONS UP TO MY DVD PLAYER. I HAVE PIC AND AUDIO BUT I GET A BUNCH OF SLANTED LINES ALL OVER THE PICTURE. WHEN I TRY TO HIT THE MENU BUTTON THE WORDS THAT COME UP ARE ALL GARBLED AND HARD TO READ...BUT IF I CROSS MY EYES AND TURN MY HEAD JUST RIGHT I CAN USUALLY MAKE OUT SOME OF THE WORDS..... MY HUBBY IS AT WORK SO HE IS NO HELP!! CAN YOU GIVE ME ANY HELP????
  • stevieB Dec 28, 2007
    I have the same problem with my Akai LCT42Z6TM TV as well. So far I found no solution to the problem. I am trying to get an answer directly from AKAI but haven't had much luck getting through to them. These lines are white scrambled vertical lines that appear all the time, even when I play Wii on it. I even tried to hook up an HDTV converter and that didn't help either. When I go into the menu, it is scrambled with color horizontal lines making it difficult to read. If anyone has similar trouble with this model or know of a fix for it ,please respond.
  • cheaptv Jan 25, 2008
    My problem is exactly the same too. Somebody help!
I finally got an answer from Akai customer service center. Because the TV is only 6 months old and I have proof of purchase, it will be repaired from a local Akai repair shop all under warranty. They told me it was a faulty modular chip that has happened to several of these models and had to be repaired in the shop due to some internal soldering needing to be done. I am waiting for the repair center to call me and will let you all know when the repair is completed.
I mis placed the 1-800 number but you can email them at akai@fox-international.com. They are located in Cleveland. Ohio.
Posted on Jan 07, 2008
I have the EXACT same problem
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
AKAI LCD TV/DVD Player Combo connect to Motorola DVR Cable Terminal
Please follow guidelines given in operation manuals of both.
Aug 02, 2012 | Akai LCT2701AD Television
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Aug 08, 2010 | Sony Televison & Video
I hooked up the dvd but I get a picture but no sound
audio cables need to be hooked up as well not just a video cable.
usually red and white and clearly colored on the output side of the dvd player and the tv. input is on the tv output is on the dvd, also if you are using a fiber connection (optical sound) you will need a fiber cable from the dvd to the tv.
Jan 31, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I do not know how to connect my DVD to my 42 in
Tries use a RCA cable plug 2 connections ports holes red,white audio out input connected ur DVD player,connnect the other side the RCA to TV audio in input.Use a S-Video cable for video connection to get video.If u have the new version of a DVD player just use a HDMI cable plug one end to the DVD player the other to the TV.
Dec 15, 2009 | Vizio L32 32 in. LCD HDTV
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Jan 01, 2008 | Nakamichi DVD-10S
Green Blotches and Bars
I have determined that mine had a problem with the composite input board. I was able to unhook the connections to this board inside the TV, after Akai, and the local repair guys couldn't figure it out....
The problem hasn't come back in a while, and since my setup is all HDMI/Component ins, I didn't affect me at all.
It looked like there was slight heat damage to the board, but not enough that it was caused by a design flaw, more like a manufacturing "accident".
Oct 21, 2007 | Akai PDP4225M 42 in. Plasma Television
Akai LCT4216 42 in. LCD Television Logo
82 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
