Question about Logitech Inc MM50 Portable Speakers iPod Computer Speakers
Speakers work when plugged into electrical outlet however will not work on battery power
Speakers work when plugged into an electrical outlet however will not work on battery power. Speakers are only two weeks old.
Any ideas on how to fix.
  • 1 more comment
  • Ruagh Jan 05, 2008
    How long does it take to charge batteries for the first time?
  • Anonymous Jan 16, 2008
    Same problem
  • Madmikebagdad
    Madmikebagdad Nov 17, 2013
    8 hrs
    New Friend:
  • 35 Answers
It sounds like you need to buy a new battery. The battery for the MM50 speaker is VERY hard to find. Logitech does not make a replacement battery for this unit but here is a site that carries it: Replacement NTA2335 Battery for Logitech MM50 iPod Speaker
I hope this helps!
Posted on Jul 23, 2013
    Problem Solver:
  • 7 Answers
Hey u r using speakers..so i think power is not suff for them to run..so use dc flug boards..i mean direct curr...
y do u try for a batery??itz waste of money
Posted on Jan 08, 2008
How do I get power
Older passive computer speakers do not need a power supply.
Modern active speakers might use batteries but mostly need a power supply that plugs into the mains power outlet and provides the right voltage, current and polarity the speakers need.
Some low-powered active speakers simply plug into the computer usb.
Oct 05, 2015 | Audio Players & Recorders
Gateway built in laptop speaker are sqeeking
Laptop speakers often suffer the consequences when you snack while using the laptop, usually while surfing the Web.
Small particles of chips, crackers and other sources of crumbs easily fall into the little holes of your laptop's speakers, therefore causing sound distortion.
This sound distortion problem can be fixed by cleaning out your laptop's speakers with a safe process that does not require any dismantling of the laptop.
Turn the laptop off, unplug the power cord and remove the battery to lower the risk of damage to the computer and electric shock.
Wipe away any exterior debris using a cotton swab.
Dip the cotton swab in rubbing alcohol and swab away to remove any sticky residue.
Rubbing alcohol dries quickly, making it ideal for cleaning electronics.
Use a hand-held vacuum with the brush attachment to vacuum out any debris in the speakers.
A full-sized vacuum may be too powerful and can damage the speakers.
Reinstall the battery, plug the computer back into the electrical outlet and start it up.
Hope this helps
Nov 03, 2012 | Gateway M305CRV Notebook
Only one speaker working in hp dm1
This could ba a hardware problem with the power connections or dust
hope this helps
Oct 17, 2012 | HEWLETT-PACKARD Pavillion DM1-3020US...
Headphones work but no sound from either of 2 sets of speakers.
Are speakers turned on with volume up?
Are there batteries in the speakers of not powered by the outlet?
Are the speakers plugged into the wall as well as the computer's earphone jack?
Is windows set on mute?
I would check the above first.
Jul 14, 2010 | Dell Inspiron 545 (884116037743) PC...
New Computer No Sound
check where you plugged your jack on your pc. usually it is green in color.
check the volume control on your task bar. it might be just too low or mute.
some old speakers, require batteries.
check your speakers if is plugged on power outlet.
May 31, 2010 | Bose Companion II Computer Speakers
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
Speakers
the computer speakers should have some sort of power going to them, whether it being battery powered or plugged into an outlet.
Feb 24, 2008 | HP (ZD929AA) Computer Speakers
No power to speakers
Lol, sounds like that iPod sucked the power out of your house. Just kidding. If it is plugged into a wall outlet, make sure that the conections are not bent or warped in any way (remeber this stuff is very fragile so look for the smallest stuff). If it is plugged into one of those multi outlet devils, make sure that is not too clogged up. For those I always use the Male Bathroom Ediquate rule, never stand (nor plug) next to a guy in another urinal.
Jun 06, 2007 | Altec Lansing iM3 Computer Speakers
256 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
