Question about Sonic RecordNow! Deluxe 7.3
Quicken Data File
I am able to back up my Quicken data file to a CD but I cannot open it.
The message reads: Cannot open because it is a read only file.
  • 140 Answers
Just copy it to hd, open properties (right click file and choose properties) and uncheck "read only" attribute.
you will have a normal file again.
remember that every file burned to cd, will receive the read only attribute.
Posted on Dec 02, 2007
SOURCE:
I have given up on Quicken technical assistance. Looking for paid assistance. Quicken Application quit unexpectedly (said the prompt)
Almost certainly your Quicken data file is corrupted. This is not your fault, Quicken routinely corrupts data files all on its own. Instructions for recovering your data and creating a new, uncorrupted data file are here:
http://quicken.intuit.com/support/articles/data-file-management/data/4748.html
Don't be surprised if Quicken also crashes while following these instructions. Sorry to be the bearer of bad news, but that's just the way the product is.
Oct 28, 2009 | Apple iMac G4 Desktop
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
Sony crx 230ee
Hi Rolyn,
This problem is a result of the fact that Quicken needs to compress and adjust the file on the fly as it write it. CD/DVD disks cannot be edited on the fly so the program sees them as an invalid choice. Save your backup to the harddrive, when it's done drag and drop the file to the CD or use your CD burning software to make a copy on CD.
Hope this helps FixYa,
Chris
Jul 12, 2009 | Sony CRX-230EE (33383923840) Burner
I am getting the message,
Find the saved file. Right-click on the data file and left-click on properties. Then select the security tab to see permissions. Alternatively, give yourself administrator privileges to open the file.
May 09, 2009 | Intuit Quicken 2008 Deluxe Full Version...
Using the same quicken file on two networked computers
After you install Quicken on both computers it is no problem. If you put the Quicken file (the data is on the file that ends in .qdf, on a flash drive (you should be able to get one for $15 or $20) , you can carry the file in your pocket on a key chain. Then any time you want to use the file just double click on the file and Quicken will open on either computer. Make sure yo password protect the file and also back it up to one of the computers frequently in case you loose the flash drive.
Mar 20, 2009 | Intuit Quicken® Premier 2006 Full Version...
New installation on Toshiba lap top. Unable to transfer data from Quicken 99 on IBM lap top. IBM did not recognize flash drive. Copied to email and sent from IBM. 3 messages below with attempts to add...
Try reinstalling Quicken 2008 after uninstalling it first via 'Add/Remove Programs" in Control Panel. this should help.
Also check out THIS article on converting Quicken files to new versions and other info..It may prove to be quite useful..
As for the IBM Laptop not recognizing the flash drive, generally they come with a driver CD. Try installing that on the IBM and see. If you do not have the CD, you should be able to find the driver from the manufacturer's website, or do a google.
Should you have any further questions, please feel to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 19, 2008 | Computers & Internet
Backing up a Quicken file
This is probably due to an update. Quicken and quickbooks perform updates in the back ground on a frequent basis. The easiest way to take care of this problem would be to create a directory called backup on the flash drive and instruct quicken to backup to it.
Provided you're using windows XP, click on My Computer, select the icon for your flash drive, F: Right click and create a new folder and name it backup. In quicken when you go to backup, just change where it says F:\ to F:\backup
this should fix your problem. Please email back if you have any problems getting it to work.
Dave
Feb 28, 2008 | Computers & Internet
Quicken 2004 Installing on Windows Vista
Jan 18, 2008 | Intuit Quicken Basic 2004 (028287007543)...
Sonic RecordNow! Deluxe 7.3 Logo
815 people viewed this question
Top Sonic Computers & Internet Experts
Marvin
Marvin
Norman Al-Anbar
Goldi Kunal
Are you a Sonic Computer and Internet Expert? Answer questions, earn points and help others
