1993 Ford Escort 4 Door Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace my 1993 ford escort GT's slave cylinder
Its a 1993 Ford Escort GT with a manual transmission. It is leaking fluid from underneath when i crank the car and try to put it in gear. it will not go into gear and will not go anywhere but will crank. when i release the clutch the motor shuts off. im pretty sure its my slave cylinder. how do I replace it???
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
461
Points
I have a ford escort LX 1993. I just started to feel my gears getting stuck in one gear or another. I wanted to know if it was my slave cylinder. adn if so, where can I get one?
pieter dauth
Level 2:
  • Expert 68 Answers
  • Posted on Aug 11, 2009
pieter dauth
Expert
Level 2:
Answers
68
Questions
Helped
22406
Points
167
Just unbolt it and undo the pipe then refit the new one the sme way in reverse order
2answers
What's wrong with my clutch if my 1998 escort won't go into gear. There is small resistance in my clutch pedal
Jamie, are you losing any fluid from the clutch master cylinder? By small resistance I presume you mean the pedal feels soft?
If you're losing fluid from the master cylinder you have an obvious leak somewhere and air is getting into the system.
Most leaks occur from the clutch SLAVE cylinder as it does all the work .. If there's no leak from the clutch slave cylinder, suspect the seals inside. It's like a bicycle pump ..the seal inside wears and it won't pump..
You may be able to get an overhaul kit. I'm in the UK .. but here's an Ebay link for a slave cylinder overhaul kit just to show you what it looks like:
FORD CORTINA MK2 CLUTCH SLAVE CYLINDER REPAIR KIT SP2085
Here's a link to show you what the slave cylinder itself may look like (it may NOT be for your vehicle..)
CLUTCH SLAVE CYLINDER FORD FIESTA ESCORT
It's easier and quicker to fit a new slave cylinder than it is to strip down and replace seals with a kit. Be aware, after overhauling or replacing a slave cylinder you have to bleed it - remove the air.
The easiest way of doing this is to make sure the reservoir is fill of fluid, crawl underneath the car with a spanner/wrench, place a rag over the bleed point and get somebody to pump the pedal a couple of times while you undo then tighten the bleed nut.
If it's not the slave cylinder at fault- then it's the master cylinder. Master cylinders also have a 'piston' and rubber seals which wear/perish.
However, it's more than likely that it's the slave cylinder at fault
How do I remove a slave cylinder that is stuck n won't come off?
Hi Paula:
Assuming that it has failed and is being replaced, there's no need to be overly gentle.
Remove the fluid delivery tube by undoing the connector.
Remove the bolt(s) that secure the cylinder.
It should now be able to be removed with a couple of delicate taps from a ball pein hammer, or some gentle prying with a screw driver.
Cheers,
1993 ford escort gt automatic transmission is pouring out fluid
Grab some kitty litter, soak up your mess, and look for where the leak is coming from.
1992 ford escort
fill clutch master cylinder. there should be a slave cylinder at top of trans case. bleeder on slave cylinder. crack bleeder with clutch applied. (pump up and hold). do same thing until stright fluid comes out of bleeder.. clutch should be solid after this operation.
1helpful
91 ford escort gt wont go in gear
If you mean the clutch master cylinder, you could have air in the line, or a faulty cylinder. The clutch hydraulic system works the same way the brakes do, it uses fluid pressure to push on the slave cylinder in the transmission housing.
3helpful
Replacing a master and slave clutch cylinders on a
remove the battery and the battery tray,the fluid line and the two bolts that hold on the clutch master and remove.you may need to bleed the new one at the slave cylinder by having someone depress the pedal and letting the air out and tighten the line again before they release the pedal,but i think by pushing the pedal up and down a few times it will be ok. if the shifter wont go into gear or the car starts to move when only slightly moving the pedal of the floor then bleed it.
I have a 1998 Frord escort Zx2. when you
Make sure it is full of brake fluid first. If it is, check for leaks around the clutch master and slave cylinder. The master cylinder is mounted on the firewall below the brake master cylinder and towards the driver side. Follow the line to find the slave cylinder on front of the transmission. If you find no leaks, either the master and/or slave cylinder is bad or the clutch fingers are broken.
How do I check the transmission fluid
With that Burning Smell it is the Transmission Burning up the Clutches on the Inside. Gonna have to get it Rebuilt.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
