I hooked this dvd player up and at first the sound was distorted with some weird background noise and now I have absolutely no sound coming from it at all. The picture is fine but no sound please help!
go to the menu and to the setup and go to sound...make sure that the right format is selected for the movie and that the right output is selected for the output your using....if the sound is intermittand you more than likely have dry solder joins on the board...to fix this you ned to disconnect the unit from the mains and remove all screws to open the unit up and then take out the PCB and screw holding the RCA blocks and remove and use a soldering iron and solder to re-solder all connection points between to RCA array and the PCB
hope this helps,ben
i have a power suply problum with 622/97 model philips dvd player, one of the ic is exploded because...
(More)
I HAVE A POWER SUPLY PROBLUM WITH 622/97 MODEL PHILIPS DVD PLAYER, ONE OF THE IC IS EXPLODED BECAUSE OF I CAN'T READ THE IC NO..PLEASE PREFER A COMATIBLE IC NO
I don't have the original remote for my Magnavox 27 in. tv. How do I get rid of the parental control...
(More)
I don't have the original remote for my Magnavox 27 in. tv. How do I get rid of the parental control that shuts my tv off every day for 70 minutes?
