Fedders A7DH65B2A Dehumidifier
Problem for Fedders A7DH65B2A Dehumidifier
Signs of a bad compressor or condenser
By melkarau on Aug 11, 2009
signs of a bad compressor or condenser
Solution #1
posted on Aug 11, 2009
Not Rated)
rustyteague
Rank: Master
Rating: 88%, 12 votes
plug this unit into a receptacle with a lamp also in the recept. unit will try to start the lamp will dim for a couple seconds and go back bright unit wont start maybe fan but no comp. sit and watch a few minutes later lamp will go dim again then back to bright, this is a classic low tech way of confirming the comp is trying but not working possible bad run capacitor, much cheaper than new unit
Was this helpful?
Yes
No
Popular Solutions for Fedders A7DH65B2A Dehumidifier
Questions and Unsolved Problems for Fedders A7DH65B2A Dehumidifier
Do you recommend Fedders A7DH65B2A Dehumidifier?
Answer
Answer
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!... (More)
Answer
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the... (More)
Answer
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no... (More)
Answer
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fedders A7DH65B2A Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
