Question about Canon BJC 2000 InkJet Printer
Blurred, uneven printing
New cartridge in place but the printed document looks like the ink is not coming through evenly, Hoe do I clean the head?
  • Hiwatha May 20, 2008
    I bought a new Canon black ink cartridge a week ago. My documents print really crappy-looking, not solid black, as I'm accustomed to.
    Sniper:
  • 52 Answers
I would first try going to printer troubleshooting screen on your PC by clicking the "START bar" then select "Control Panel" next select the printer icon and then select the "Troubleshooting Printer" this will guide you through all the steps to aligning your print heads and cleaning the print cartridges. If that doen't solve the problem for you, I would then go to the internet and type in www..canon.com/printers then enter the model of printer you have. If you find any of these suggestions helpful, please rate my solution. Thanks D. Lange
Posted on Apr 24, 2009
SOURCE:
My printer is printing blurred letters on documents. how can I fix this. I have tried cleaning the ink cartridges but problem persists
If this isn't a driver issue I'd check to be sure the print head and ink cartridges are secure and not loose. Also check the drive belt on the head to be sure it's not slipping or broken.
Apr 13, 2015 | Canon Pixma MG3150 All-In-One Color...
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Yellow cartridge stopped workin halfway through a document although nearly full
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Lexmark Z600 ONLY print test pages
Seemes very daft, and sounds like a twit, but not really.
When I recieved the new cartridge I placed it in the correct cartridge retainer in the printer matching up the dark green colour of the cartridge and the top clip, and it printed nothing even after a tryed re-seating it.
So I placed it in the other thinking maybe I somehow might have placed it in the wrong slot, so I placed it in the other (Colour), and set that up as I did the other, and it printed a blurred page but then stopped printing.
After that I then placed it back in the other cartridge retainer, set it up as the previous times when it did not work, and then it worked.
Seems strange and simple, but it did not work the first time at all, and after faffing with it finally did.
This might help someone, and then again might not.
Oct 07, 2008 | Lexmark Z515M InkJet Printer
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Test page always blurred
It would appear as though the ink cartridges were not securely in place. Upon making them secure my test page printed perfectly thereafter.
All four requirements were carried out i.e. clean/deep clean/print head alignment/nozzle check
Tks for your respons
guru1234.
Feb 07, 2008 | Computers & Internet
Cleaning the printer head?
print heads are built into the ink cartridges on HP's. I currently have this problem with another hp model. I appears that the firmware is stuck in what is called 'econo mode' and won't come out of it. good luck. sorry not more help.
Sep 12, 2007 | HP PSC 1410 All-In-One InkJet Printer
Fax mach 1800c brother
Although you may not use the other colours the cleaning assembly cleans all the cartridges hence the other ink gets used. To trick the machine into thinking there is ink in the cartridge, place some black tape over the top of each cartridge facing front of the machine. This fools the sensor into seeing no reflected light and reads that there is ink in the cartridges you do not use. Pleas enote that if you do this on a long term basis it is liley the head will dry out and may damage the head - use this advise to get urgent prints out.
Sep 08, 2007 | Office Equipment & Supplies
Test print great, document printing blurred
Have you tried a new cartridge yet? I know it doesn't make sense at first but I suspect the cartridge has a problem and your test print isn't exercising the printer like the Word doc is. If the new cartridge works than the problem is probably poor quality ink, the hole you used to refill isn't sealed correctly or the cartridge or jets were damaged in some way.
Sep 02, 2006 | HP DeskJet 3325 InkJet Printer
Canon BJC 2000 InkJet Printer Logo
108 people viewed this question
Clive
Clive
old marine
old marine
Ekse
