Question about Mitsubishi WS-55819 55" Rear Projection Television
No pic but sound ok
My TV has no picture at all but sound perfect.
Do you have any idea?
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence
Posted on Dec 07, 2007
SOURCE:
Picture overlaid with multicoloured horizontal bars & small rectangles on both TV & DVD. Sound on DVD ok. Switched off awhile, no change.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 17, 2015 | Panasonic Viera TX-32LX70 32 in. LCD TV
Sansui sv 3220 lcd screen just white,but sound ok
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 23, 2015 | Sansui Televison & Video
Hi my lg lcd model no 42LB9DE works fine apart from 1 tv channel has perfect pic but no sounds have re-tuned tv many times to no avail... any ideas ? Tv antenna is is proper working order only 1 channel i...
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
Feb 16, 2011 | LG Televison & Video
The picture goes out on the TV but the sound still works. If I turn it off and then back on, it usually works OK for a while then does it all over again. I took it into a shop and they said that it was...
He was wrong... HDMI is just an audio/video format for high quality video and sound. That cable also contains the sound that goes with the picture. If it has sound but the picture is not there then the HDMI cable is probably OK. A simple way to trouble shoot that is to use a different input. For example Component Video. You will need a different cable for that. It only contains the picture (three wires), then change the input to component video. That's a menu setup. If that restores normal operation then your video is just fine and probably the HDMI cable is fine. The trouble may be in the connections behind the jack on your TV.
They are subject to mechanical stress when the plug is inserted and removed. They should be fine but if the connections weren't perfect from the factory they can cause microscopic cracks that will show as things like no video or intermittent video. You can bypass that connector by using a different audio/video input. If that fixes the problem then leave it that way. If it doesn't it's still likely to be a cracked soldered connection but elsewhere in the set.
Zashiban
Jun 23, 2010 | Sceptre X42GV-Naga 42 in. LCD Television
TV that has perfect sound But NO PIC
Common problem. Vertical IC or tuner need be resolder.
Thank you
Aug 05, 2009 | Sanyo DS19330 19" TV
I have a 4gig Maxell flash drive in which I store family pics. Suddenly, when I plugged it into my laptop the other day, I was told it was not formatted and did I wish it to be so. Obviously I clicked on...
Try it on another pc and if it works fine back up your pictures.
Go buy a new flash drive.
Then go to mozy.com and sign up for an online offsite storage account.
You can get a free 1yr account with 5GB storage
Nov 05, 2008 | Computers & Internet
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
Picture in picture / or picture problems
First thing you should try is unplug the set for several hours. If you have the same problem, then you are going to have a system control issue and or a standby power supply issue. These problem, unless you know how these circuits work in a TV set, will need to be looked at by a trained tech. Good Luck
Aug 13, 2007 | Sony KV-35V75 35" TV
Mitsubishi WS-55819 55" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
