Question about Husqvarna Viking 1
Changing script size on Cassette B
I don't remember how to change the script size on Cassette B. Can you help?
  • 25 Answers
What machine do you have exactly?
#1 or #1+
Posted on Jan 17, 2011
    Problem Solver:
  • 12 Answers
If you have lost your information booklet the best thing is to reorder one from the company. You can do this by going online and simply typing in the name and no. of your machine. Most manufacturers will send a new book free. They may also have a number to call for that information.
Zelma
Posted on Jan 19, 2008
How can I get the monogram to work properly?
On my sewing machine that would be an indicator of misadjusted thread tension. Changing thread type or diameter generally requires tension adjustment. In this particular case, I\'d increase the bobbin tension a bit (if I understand your description correctly, the bobbin thread forms loose hoops), and back off on the upper (spool) tension (pulls too hard on the thread). On one or two of my bobbin cases, I had problems with the tensioner screw working loose during use. I put a dab of nail polish on the screw head to stick it to the bobbin case. Problem solved.
I\'m not familiar with your particular machine, but I don\'t see why you can\'t make the character any size above the minimum (which would be the smallest readable character that can be made with the stitch length and type used).
Apr 24, 2014 | Kenmore Elite Clothsetter 19010
Not overlocking
try changing the needle
and adjusting the tension
if these suggestions don't help then the machine could have jumped time & needs to be serviced
May 11, 2012 | Sewing Machines
Sewing in reverse cuts top thread, help? Please!
the fabric & thread & needle may not be compatable
try changing the needle- it may be damaged
the horrible grinding noise needs to be check --the machine needs to be serviced
check for burrs on the needle plate & on the bobbin
some sewing machines don't do with strong material
Mar 18, 2012 | Sewing Machines
After taking only a few stitches, the bobbin thread becomes tangled and knotted. I've cleaned and oiled the shuttle and cover and adjusted the tension, but it still happens. Advice?
have you tryed changing the needle?
have you tryed changing the thread on top & bobbin area?
some thread & needle are not compatable--here's a tip I learned from a sewing expert
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
hope this helps
Oct 12, 2010 | Husqvarna Husky 145
Knots!
Try changing the needle sometimes over use causes burrs on the end of a needle and always remember to use proper needles to appropriate fabrics. Change needles frequently to avoid unnecessary wear on the feed dog teeth
Dec 12, 2009 | Janome Memory Craft 10000
I need a replacement needle to embroidery. need to know the model#. I have a Brother SE-270D Easy Thread Cassette System.
The thread cassette has no bearing on what needle you use. You need a Schmetz embroidery needle with the red band size 75 for light to medium weight fabrics or a size 90 for heavier fabrics such as denim.
Dec 07, 2009 | Brother SE-270D Computerized Sewing...
Consew 230 continually breaks top thread at needle
What size thread are you using? With thicker fabrics, you should be using at least a size 50. Even a 30 would be better.
Oct 18, 2009 | Consew Sewing Machines
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
Wont thread
Check the needle size in comparison to the thread weight. Look in your book at the suggested needle size to accomadate the thread weight. At the very least try changing the needle, hope this helps.
Aug 23, 2006 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
96 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
