Question about Panasonic PT-52LCX65 44" HDTV
Red, purple and green dot
When I turn television on tells me to change the lamp and reset. There is also a red, green and purple dot on my screen, but they only show up when light colors are on the screen any at home fixes that I can try?
  • biggus35 Jan 06, 2008
    My Panasonic PT-44LCX65 is having color problems as well. Started off with a blue area near the bottom middle of the screen. Now there is a green area on the right side a little over halfway down.
  • DAN GENZLER Jan 06, 2008
    i have the same problem. 2 blue spots on right side and 1 green and 1 purple on the left
Its the light engine. Had a tehnician come and look at mine and was told it would have cost over $600 if I didnt have the warranty. Panasonic called 2 weeks later and told me that parts are no longer available for my model and are upgrading me to a 50 inch tv.(from 44 inch)
Posted on Dec 10, 2007
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Replaced lamp in projection tv PT52LCX65-K1.Now have a green and purple image 3 -4 inches slightly to left of screen,also a purple one to right of centre,they appear intermittantly.Also the change lamp,and...
First- Did you replace just the lamp itself. If you did, you must make sure the lamp is flush into the lamp cage.
Second - Make sure the new one (if you bought it complete with cage) is flush also.
If you didn't have this problem before and have it now then retrace your steps.
Dec 20, 2010 | Panasonic Televison & Video
First our tv had purple dots now we have about six tiny black dots on the tv screen. We notice we had large purple dots running vertical on our tv screen. A couple of days ago we noticed a small black dot...
well u have stopped ur movies(dvds) to many times and the dots are burn marks on ur screens
if u read ur manual it will tell u NOT to leave a still picture on for to long as it will damage ur screen
i assume u have a PLASMA TELEVISION
if not... sorry cant help u
Nov 20, 2009 | Televison & Video
What is phosporing screen
The colored spots may be a light engine issue that Panasonic will pay for repair costs even though tv is few years old. Contact Panasonic. . No you can't reset the lamp timer without a remote.
Oct 11, 2009 | Panasonic PT-52LCX65 44" HDTV
Growing number (now six) small green dots on right side of screen of 65" DLP rear projection Mitsubishi HDTV. Annoying -- how to fix?
Replace Light Engine, pretty soon you will have Dots All over screen with green and purple color. Call UED for price of rebuilt Light Engine 1-800-648-6657 ask for Melissa tell her ladywinn said Hi.
Sep 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Laptop screen has been invaded by green and red/purple germlins
haveyou tried shutting it down and restarting it? it may just be the screen going bad
Jan 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Dots on screen
you have to get a repair guy to come out. When this happened to me the guy changed the bulb (which didn't work) and the actual internal projector (which did work). But he had also said there was a software fix for this problem that is considerably cheaper.
Nov 29, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
240 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
