Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Stop working Print hhead does not move. Made a grinding sound and went far right and stopped. Scanner won't scan, fax won't work. Alarm light flashing and menu reading check printer and press set.
  • 4 more comments
  • wendybird Nov 29, 2007
    Having the same problem: print cartridges are stuck, all the way to the right, makes a grinding noise and won't do any other functions. Please let me know if a solution has been found. Thanks.
  • Anonymous Dec 08, 2007
    same problem. print head cartridge carrier is jammed at far right and 'clicks" but doesn't move. I tried to open the unit up to get a closer look but was unable to get past the back panel. Repairs are generally expensive so i'm considering buying a new Multipass but hate to give up the two ink cartridge on this 390
    Please help with guidance (smile)
  • bigjohnw Dec 15, 2007
    Print heads stuck on the extreme right and when I try to
    reset it make a clacking sound (8-10 clacks) but nothing
    happens. I can't figure out how to open the case. Anybody
    know how?
  • Encino Dec 16, 2007
    Message is print cartridge jammed. There is no paper jam. When I press the set key, the printer whirs for a while, tries to move the print head and clicks twice but the print head does not move.
  • Anonymous Jan 02, 2008
    printer cartridge jammed
  • Woodi Aug 21, 2008
    Canon MP390 - When trying to print print head doesn't move from R.H. position, multiple clicks heard and error light flashes. Message says press set but problem does not correct. Cartridge access panel on front seems locked. Is it time to trash the printer or is there an inexpensive fix? It seems to be a common problem.
The covers are pretty easy to remove and access print catridges once you know how. Unscrew screws as they become available, 4 on back then two on each side then 4 on top. the balck plastic front bezels pop off as do the grey side panles. Try pulling out and up from the top. This can be a little tricky but I have not had to be too brazen and have not broken any panels. I am pretty sure that clicking sounds indicates broken parts and a trip to the repair shop. Basically the lock to keep the heads covered is not disengaging.
Posted on Feb 11, 2008
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
2005 tahoe rear access door ajar alarm won't stop going off
I HAD THE SAME PROBLEM WITH MY REAR DOOR TAHOE 2001 ., I TOOK IT TO THE MACHANIC AND IT WAS SO SIMPLE A FUSER UNDER HOOK . $8.00 FUSER ., IF I WOULD IT KNOW . I WOULD IT DONE IT MYSELF.-- REPLACE FUSER WHERE IT SAID --HORN- ITS UNDER THE FRONT HOOK... I END IT UP PAYING $120.00 FOR THEM TWO HOURS WORK...THE LIGHTS AND THE ALARM WAS NON-STOPPING MAKING NOISE..... RIGHT..????
Sep 20, 2012 | 2005 Chevrolet Tahoe
I have a Canon MultiPass MP730 that is flashing the Alarm and reads cartridge jammed. However I can move the cartridge manually. The machine won't do anything because of the alarm. How do I fix this?...
To fix this you first need to remove the ink and the print head.
Wash the 4 ink pads in luke warm water.
Keep running the water over the bottom of the print head until the water shows no sign of ink colouration.
Make sure all of the print head is completely dry before replacing it into your printer.
After restarting your printer you will probably see the alarm light still flashing.
Now hold your finger on the resume button for up to 2 minutes or until you hear a clunking sound.
Hold your finger on this button and the printer will fix itself and the alarm light will stop.
Aug 30, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
My Canon Pixma MP990 stopped working. First the wi-fi light went out, and the LCD screen went dead. Then the blue light stopped coming on at all, and all I have when I plug in the printer is the yellow...
It sounds like you have an electronic problem, it is most likely a faulty scanner or logic board. although a faulty print head can take out a logic.check that there is no burning smell or damage evident on the underside of the print head before trying a logic.
the machine will require disassembly and parts replacement.
Aug 16, 2011 | Canon Pixma MP990 InkJet Printer
My photocopier AR-F152 IS NOT WORKING,the L2 flash on the lcd
an l2 code is your scanner is not moving. sometimes the little lock under the scanner section get pushed or turn. this is stop the scanner from moving in transport. it is right above where the paper comes out. you will have to look for it. it protudes uner the glass to stop the scenner.
Dec 28, 2009 | Sharp AR-F152 Fax
Canon PIXMA MP240 scanner problems (physicl, not digital)
when i load paper it feed cockeyed,,,when rollers start it appears to only fee on one side and crinkles paper ..turns sideways and stops feeding....Help !
Nov 24, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Cannon MultiPass C5500 fax machine
turn it off
unplug it
wait a few minutes
plug it back in
turn it on
try printing to it again
Feb 17, 2009 | Canon Office Equipment & Supplies
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Canon multipass 390
alarm is flashing and flashing put in cartridge even though I've put in both black and color new cartridges and reset both still won't print
Mar 25, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
174 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
