Candy CPCA240FFK Bottom Freezer Refrigerator
Problem for Candy CPCA240FFK Bottom Freezer Refrigerator
There is water leaking out of my bottom freezer
By helen_seale on Aug 11, 2009
there is water leaking out of my bottom freezer
Solution #1
posted on Aug 12, 2009
Somewhat Helpful)
e-Guru
Rank: Wiz
Rating: 84%, 284 votes
The reason for your fridge to leak water on floor sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a boaster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Thank you for contacting Fixya.com
Was this helpful?
Yes
No
Solution #2
posted on Nov 12, 2009
Not Rated)
sexpot277
Rank: Apprentice
Rating: 0%, 0 votes
for the last couple of days my fridge freezer light has been flashing constantly, And starts to defrost, got up this am, turned it on and it keeps blowing my circuits
Was this helpful?
Yes
No
Popular Solutions for Candy CPCA240FFK Bottom
Questions and Unsolved Problems for Candy CPCA240FFK Bottom
Do you recommend Candy CPCA240FFK Bottom Freezer Refrigerator?
Answer
Answer
You turn the knob to say medium, the fridge appears to be working normally, the light goes on, the... (More)
Answer
i own a candi cpca 240 and the fridge is freezing all the food how do i turn up temperature ?
Answer
the freezer stops working and the food is defrosted what is the problem
Answer
Candy Frostfree Fridge freezer, model CPCA240FFK My Candy as above is getting too cold.
Answer
CPC240FF fridge wont work. The Freezer section works but the fridge wont get cold. I have changed... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
