In Ubuntu 9.04 click on the main icon and select Restart.
- If Ubuntu is the only operating system on your computer you'll need to tap the ESC key as the system boots.
- If you have a dual boot or multiple-boot system the menu should appear on its own.
- At the root level you'll get a boot menu. Select the one that says "recovery mode" and press Enter.
- Ubuntu continues to load until you reach the Recovery Menu.
- Arrow down to "
netroot
" which states Drop to root shell prompt with networking and press Enter.
- Now, at the root type "
password username
" (where username is the account whose password you want to change) and press Enter.
- You'll be prompted to
enter a new password
- You will not see the password or any evidence that you are typing.
- Retype the password. If both passwords match you'll have successfully reset your password.
- Press Enter to continue booting into Ubuntu.
hope it helps
couple of ways. You can reset your router, then it will default to factory settings and then it will delete your password and open itself up to not needing a password to get on your network. However, anyone can connect to your network, so you will have to enter into your networks menus and reset a password to prevent this, then set that password on all of the computers on the network now. You generally access your set up menu by typing your server IP address into your browser address bar, which is ususlly http://192.168.1.1
This is not all conclusive as some routers have other access methods, but the majority use the above. It will also require a User and a password and the default is usually admin and password or password1 for the default. If however, you have set a password then you definitely have to reset.
Reset is usually a small button , some recessed in a small hole that requires a tooth pick or un-bent paper clip to push into the hole and hold for 15 seconds with the power on the router. Sometimes turning the power off of the router for 2-5 minutes will cause it to reset.
You can also force the laptop(or any client of that server) that you are using and is connected to the internet to give you the english translation of the password. Click on your WiFi icon down in the right corner, A window opens,right click on the name of your network that is connected, click on properties, click on "show charcters." The network key(your password) will be revealed
No real default, but if you do not have file sharing turned on on whatever server you are connecting to it will ask for a password. Make sure you have public file sharing (with no passwords) set up on the server.
