Question about Frigidaire PLEB27T9DC Electric Double Oven
Lower oven won't heat
Last used the lower oven Thanksgiving of 06. It worked fine then - self cleaned it then also. This year, it barely warmed ( maybe 200 ) and now, it does nothing. The indicators on the control panel appear normal....
Top oven works fine.
  • Sailer1 Feb 15, 2008
    Almost the same. The lower works fine, the top is the problem. It will get to 220 degrees and stops.
  • Dual Pain Oct 26, 2008
    Cleaned the oven and then the lower oven would not heat up. The lower element was not getting hot so I relplaced the element...the oven still does not heat up. The upper element heats up in the preheat mode but the lower element is not getting hot at all. What could the problem be?
    Champion:
  • 249 Answers
It must be thermostat in bottom oven
Posted on Nov 29, 2007
  • eamonn close Nov 29, 2007
    sorry' it could also be element
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Aug 31, 2009 | Frigidaire 30 in. Electric Double...
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
After Self-Cleaning the lower oven wont heat up!
There is an overheat sensor that may have failed to the open position. It is a little round button thing a little larger in diameter than a dime with two wires. Check to see if it is in the open position
Jul 30, 2007 | GE JKP45 Electric Double Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Frigidaire PLEB27T9DC Electric Double Oven Logo
295 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
