Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Dots on screen
I have a Panasonic PT-50LC13 television and when I turn the television on there is a red, green and purple dot on the screen is there a home fix I can try?
  • Stepp2 Dec 03, 2007
    A green dot in center of screen has appeared. When a baseball game is on the dot mimics the ball. How is this fixed?
  • ron4055 Feb 15, 2008
    On the right side of my screen I have a bright dot, it changes colors for the most part and is not noticable when there is a black back lighting. Do you know what it is and how it can be removed.
You have to get a repair guy to come out. When this happened to me the guy changed the bulb (which didn't work) and the actual internal projector (which did work). But he had also said there was a software fix for this problem that is considerably cheaper.
Posted on Feb 15, 2008
SOURCE:
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
On the screen is a small green dot in the upper right...especially noticeable during dark scenes on shows
There is a software update for that unit but you will need a shop that has the box to do it with. This box is provided to authorized shops. I recomend you find a shop that is a panasonic warranty service center.
Oct 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
After the lamp expired I have two red spots in the picture
There is only 2 things that will cause this and one is Dirt on optical Lense OR Light Engine is going BAD if light engine is it it will start showing more spots along with tiny DOTs and color on picture will be green and purple in different areas.
Aug 18, 2009 | Panasonic PT-40LC12 40" Rear Projection...
PT-50LC13 won't turn on. Will blink green and make a chirp noise
It is the balister not the lamp. Very common problem that Panasonic will not address. Costs over $600 to repair. file a complaint with consumer affairs please.
http://www.consumeraffairs.com/php/a_report.php
Jul 03, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-61LCX65 tv has color spots
if you mean color spots size of a dime or so.
  • easiest: it is dust in some step of the projection light path.
  • hardest: the light engine could be damage
if you mean little ones as little dots (a neddle punshing) red and blue but always there:
  • condition call it: pixels always on: light engine is the reason.
as you see the light engine is the main part here, IT is expensive repair. so if you can survive with those little dots do it.
IF it is dust, is good idea asking for and estimate to see if can works.
Apr 04, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Red, purple and green dot
Its the light engine. Had a tehnician come and look at mine and was told it would have cost over $600 if I didnt have the warranty. Panasonic called 2 weeks later and told me that parts are no longer available for my model and are upgrading me to a 50 inch tv.(from 44 inch)
Nov 29, 2007 | Panasonic PT-52LCX65 44" HDTV
Green and Blue spots on screen
Sounds like stuck pixels, you really can't fix that. Do some google research if you are curious what a stuck pixel is.
Oct 30, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
