Question about Compaq Evo Notebook Keyboard N610C/N600c
Casio LK-30 Key Board Piano
I have a Casio LK-30 keyboard that my daughter uses to practice. Where the electrical plug into the back of the unit is I'm not getting a good connection. I opened up the unit and the circuit board connection where the plug in adapter soldered connection to the circuit board is appears to have one of theese connections slightly seperated. Can I order a new circuit board. The part number stamped on the circuit board is JCM470-MANM A.
Thank you,
Mike
I have the same problem. I was thinking one solution for us, but I don't like it might be to solder the power supply on and skip that female plug entirely. To do that, you cut the male end off the transformer/power supply wire (if you don't want to ruin your transformer/power supply you can buy another power supply at Best Buy for $10 - Dynex DX-C1109). Then strip the ends from each wire from the power supply so you have some bare wire showing on each wire. One goes on the spiral thing sticking up from the JCM470 board, the other goes anywhere you want on the red wire coming from the battery compartment. You should test before you solder to make sure you the proper one on the proper wire and that you therefore have power to the unit and it makes a sound. But its a sloppy fix. While it should work perfectly, the power pack then can't be changed unless you solder and unsolder it each time. Another solution is to find a broken LK-30 or LK-33 and rob the circuit board if it still works on the parts machine. Trouble is if you find one and its not near you it costs some money to ship these. At some point its just easier to buy a used one on Ebay or craigslist.com, I guess.
Posted on Feb 24, 2008
  • 1 more comment
  • junglecat Feb 25, 2008
    If you didn't think my last idea was sloppy enough, here is one thats even sloppier, but at least it doesn't require any soldering. I just tried it and it worked okay. That spiral thingy sticking up on the circuit board forms the ground on the battery pack. If you trade the red wire to the battery compartment, you will now see which is positive and ground. I took my two stripped wires, and then with ONLY TWO batteries in the power pack, I used a couple of dead batteries to squeeze and hold in place the wires from my transformer. That way, power from my Best Buy transformer flows into the unit at the positive and negative sides of the battery compartment, with the wires being held in place by the dead batteries. As I said, its sloppy, but, also as I said, it avoided soldering and provided you don't move the unit a lot, it would work.
    Also, I just found that taking the wires to the out by the latch mechanism for the battery compartment allows the battery compartment lid to pinch the wries and hold them in place. I'm playing it right now.
    In the comment before my last one, "If you trade" should have been "If you trace". Trace the wire is what I meant.
How do add songs to the song bank on my Casio LK-30 keyboard?
You can't add songs to the LK-30 song bank. I suspect you would need to take apart the keyboard and replace the ROM (read-only memory) chip to get a different song collection.
Most Casio electronic instrument manuals are available from http://support.casio.com/en/manual/manual.php?cid=008 . However, I found the LK-30 manual at manualslib.com: https://www.manualslib.com/manual/358460/Casio-Lk-30.html .
I wish that I had better news for you.
Sep 30, 2017 | Casio Music
How do you replace a key on a casio 100 keyboard. which screws do you remove in the back
What kind/type of your Casio 100?
Casio MT-100,LK-100,CA-100,PT-100,CDP-100 ?
May 19, 2015 | Casio LK-100 Keyboard
HOW TO USE TOUCH RESPONSE
There are two samples for each note in the "Piano" sound samples. This allows you to play "soft = p" or "Loud = f" based on how hard you hit the keys.
The default setting of 2 suit most people. You can change the touch response to 3 (more hard) or 1 (less hard). With tough response set to 3 - you play mostly the soft samples until you bang the key much harder.
This is a keyboard that tries to give a bit of effect that an acoustic piano hammer mechanism would give.
Oct 29, 2012 | Casio Lk-110 Keyboard
Need an owners manual for a Casio lk-100 keyboard
you nearest casio dealer may have one in the back of the store,
many buyers don't want/need the manuals so some stores hold on to them for such occassions
Jun 28, 2012 | Casio LK-100 Keyboard
My sister has the casio LK 30 for her special needs daughter. She accidentally used the wrong adapter to plug it in and burnt something in the unit. The new casio is too complicated for my neice and I...
If it's blown a regulator in the keyboard you may be lucky that that's all that's gone.... If unlucky it could have rippled through & taken out a lot of the electronics. (aka a right off) A decent repair shop should be able to take a look & give you a price to sort it.....
Jan 12, 2018 | Casio LK30 Note Lighted Keyboard
Casio Privia Px-120 88 key digital piano frozed.
Not sure that this is the right answer.
But it works very well with other electrinic devices.
When you turn off the unit it resets itself.
ie: the parser code program on the IC (Integreated Chip) defaults to the base program
upon power up.
This problem commonly occurs from a voltage drop at a standard household outlet.
It can occur from other high draw electrical items that are on the same circuit being turned
on while your playing your keyboard.
So stay away from extension cords as these increase electrical resistance.
ie: you dont get enough power for the device.
Another thing that can cause this is power strips.
I know we all use these for certain items but they can wreak havok on electronic
components by not being able to supply enough power.
Best that if something like this happens to plug the item directly into an outlet.
And make sure that Momma's microwave isn't gonna kick in anytime soon.
Hope this info helps.
Bobby
Jan 11, 2009 | Casio Portable Keyboard Touch Sensitive...
I need a Casio LK-30 AC Adapter
Check out this link:
http://www.zzounds.com/item--CASAD5
It looks like the right one to me. I am ordering one today for our keyboard.
Aug 27, 2008 | Casio LK30 Note Lighted Keyboard
Computers & Internet Logo
697 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
