Question about Epson - PowerLite S1+ Multimedia Projector
I have a yellowish tint in the center of picture
The bulb the unit came with was defective - silver backing peeled off into the bulb after about 150hours low setting. Changed the bulb and no difference. Still have a strange yellow center tint where as the outside of the frame has clean color
Why does my picture appear yellowish on the screen? I haven't changed the bulb in at least 2 years. Does this make a difference?
Posted on Jan 31, 2011
SOURCE:
Driver side turn signal bulbs light but do not flash
Faulty flasher Unit? Have you changed any bulbs (Wattage of bulbs to low for flasher unit?) Bad earth connection to light unit (s)
Dec 27, 2013 | Hyundai Cars & Trucks
My weber genesis silver-b (sku # 218446) is 11 years old and has this "peeling problem". Is anyone "sure" that it isn't "paint/enamel" that is peeling on a model that was...
I'ts the same today as it was back then. They still use porcelain enamel. Not paint. A couple of things that could ease your mind. Paint has like a kerosene smell to it. Also, drop a chunk in water for a few days, paint will not dissolve in water.
Jan 18, 2011 | Weber Genesis Silver C Grill
How do I change the front side marker light bulbs?
Bi-Xenons - 6000K D1S
High Beams - Osram Nightbreakers H7
Fogs - PIAA H11 Yellow Ion
Cornering Lights - Osram Nightbreakers H3
Front Park Lights - High-Powered LEDs with built-in resistors
Front Signal Lights - Sylvania Silverstar 7507A ST (Silver Bluish but lights up Amber)
Front Sidemarkers - InviSilver W5W (Silver but lights up Amber)
Rear Signal Lights - P21W Stealth Bulbs (Silver but lights up Amber)
Reverse Lights - Sylvania Silverstar 7506ST or Error-Free LEDs
License Plate Lights - C5W Error-Free High-Powered LEDs
  • Turn the engine off and approach the side of the porsch with the burn-out side-marker light. If you are replacing both, start at either side; the replacement procedure is the same.
  • 2 Remove the screws from the plastic fender liner. Peel back the liner to access the area behind the fender.
  • 3 Reach your hand inside to gain access to the side-marker light's backing. Push the backing forward to release the side-marker lens; it's held in place by small clips.
  • 4 Grab the lens on the outer side and turn it over to access the back. Gently turn the bulb to release it from the plastic lens.
  • 5 Pull the bulb straight out to remove it from the electrical socket. Insert a new bulb, but do not touch the glass part of the bulb with your hand.
  • 6 Push the new bulb into the side-marker lens. Turn it clockwise to install it. Push the side-marker lens back into place. Apply gentle pressure to the lens to pop it back into its mount.
  • 7 Replace the screws along the edge of the fender liner.
  • Dec 04, 2010 | 2006 Porsche Cayenne
    Can i replace the bulb only on the low beam lights or have to buy the whole casing for it...
    Yes, you can replace just the bulb. It's not a sealed unit. There's one phillips head screw that holds in the corner lamp. Then you'll see the outer screws to remove the headlight. On the hood side, carefully peel the rubber off the teardrop shaped plastic holders. Remove the 10mm bolts and the whole assembly should slide right out. Twist the retaining ring (unplug the bulb first) that holds the bulb in. Pull the bulb out. Don't touch the glass on the new bulb as it's halogen and the oil on your fingers will damage it as the bulb heats up. If you do, clean it with rubbing alcohol.
    Mar 13, 2010 | 1997 Dodge Ram 1500 Club Cab
    How do you replace brake light bulbs
    1. Slide your fingers beneath the carpeted trunk trim and peel it away from the trunk's interior.
    2. Remove the four wing nuts that fasten the taillight assembly to the car. Place the nuts in your pocket or a small bag for safekeeping.
    3. Lift the taillight assembly away from your Grand Am's body. Press the five restraining tabs to release the assembly plate from the lens cover.
    4. Pull the defective bulb directly out of its socket and replace it with the new bulb. Once it's secure, press the assembly plate back into place.
    5. Test the new light to make sure it's working. If the bulb lights up, attach the lens cover, fasten the wing nuts and replace the trunk trim.
    Oct 09, 2009 | Pontiac Grand Am Cars & Trucks
    Headlight repair on 2003 Mercedes Benz E320
    how do you change left low beam bulb on 2003 mercedes e320
    Mar 15, 2009 | 2003 Mercedes-Benz E-Class
    Changed bulb and light still not working
    look for a silver looking thing it's a stater it twists out counterclockwise replace that
    Mar 01, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
    Replacing bulb and housing
    the front comes off, you can see the parts.
    Aug 07, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
    InFocus X2 Projector Fault
    This error is to do with the light tube - 4 retangular mirror's just after the colour wheel. The dark band is where the bonding for the mirror's is failing, the spring clip holding the assembely inplace pushes the top mirror down slightly causing the dark band as mentioned.
    To fix this use a high temp glass glue and very careful clean, reposition the mirror's (in the correct position). Allow to cure fully then re-assemble the unit.
    I have only have had to do this twice the 1st time using a sub standard adhesive and dark return a few weeks later. The 2nd I did some reseach and have a quailty glass glue. The X2 has been fine for many years now with no sign of the band re showing.
    hope that has helped you.?
    ps. if you are rubbish at doing stuff like this - just don't try, it's fiddly and requires a good understand of what you are trying to achieve. A perfect retangular tube with parrallel sides...!!!
    Sep 26, 2007 | Compaq MP2800 Microportable Projector sps...
    Epson - PowerLite S1+ Multimedia Projector Logo
    558 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
