Question about Toshiba TP50G50 50" Rear Projection Television
Need to replace screen
How do I get the front off of a Toshiba TP50G50 so I can replace a cracked screen?
  • Anonymous Feb 05, 2008
    How do you take the screen off?
The screen on my toshiba tp50g50 is cracked. where can I get a replacement screen?
Posted on Jun 29, 2009
    New Friend:
The front speaker grille on the set is removable. Under the grille, just below the bottom of the screen, will be six screws. Remove these screws and then gently pull the bottom of the screen towards you; it will swing away from the set. Then, lift the screen gently to remove it. Be careful not to damage or rip out the control cable connecting the front panel buttons to the rest of the set!
Posted on May 18, 2012
    President:
  • 4,402 Answers
It should just pull off then there will be screw holding the screen.
Posted on Dec 05, 2007
3 Suggested Answers
SOURCE:
  • 213 Answers
SOURCE: My screen is cracked need to be replaced
he part is not avb i look all on inter
Posted on Aug 10, 2009
SD Tech
  • 14553 Answers
SOURCE: need to remove front screen from toshiba TP50G50
There is a way to remove entire front screen with the frame----BUT there is a easier way to do this.
With set unplugged remove rear cover---wipe the lens you see there first--light source for picture. With a Swiffer type duster carefully reach up and in and get all the webs out.
Use no force if up against the inside of the screens as that may scratch them---much faster, safer, and easier than removing screen unit from front and avoids possible damage.
SD TECH
Posted on Jun 02, 2012
Front screen has a spiderweb crack. how can we fix this?
No, there is not. Its normal to replace the whole applicance.
Dec 20, 2013 | Toshiba TP50G90 50" Rear Projection...
Need to remove front screen from toshiba TP50G50
SD TECH
Jun 01, 2012 | Toshiba TP50G60 50" Rear Projection...
I have a crack in my projector screen can i get a replacement screen? toshiba ct-90101
have checked the net and you can get front screen replaced on any size projection tv try
email
[email protected]
Nov 17, 2009 | Toshiba 50H72 50" Rear Projection...
Your set has 3 screens:
FA812 SuperShield is no longer available
23837472 Lenticular lens is no longer available
23837450 Fresnal lens is also not available.
Check with some of your local TV shops. You may find a non-working TV with good screens for sale.
Good luck
Aug 10, 2009 | Toshiba TP50G50 50" Rear Projection...
Have a Toshiba TP50G50 Projection televison with no picture. Have 100 volts to power board
100 volts is too low to power the entire projection TV. Usually with rear projection TVs there are three tubes that create your picture on the screen. To power those tubes, they each require a high voltage (usually around 10,000 volts - yes ten thousand) that is produced by a high-voltage step-up transformer call a 'Tripler' - since it powers all three tubes. This device and the rest of the TV require full utility voltage (120 - 130 volts AC) to properly power the unit. Correct the voltage and try again - is the house / residence voltage like that in each room? IF so, you probably have other issues with devices you probably haven't picked up on.
http://www.tacp.toshiba.com/tacpassets-images/models/tp50g50/docs/tp50g50_om_e.pdf
Jun 23, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Cracked screen on my Toshiba TZ50V61
maybe I can get you one but I need the sizes in inches by the way some tv has more than 1 screen can you tell me if all of them are broken? I was unable to singn in for a while due to a problem in the system
Oct 13, 2008 | Toshiba TZ50V61 50" Rear Projection...
No picture tp50g50
Sounds as thought you have a dead B+ from the power supply board. Replacement of the board should be a certain fix. The power supply could be fixed with the help of a good service technician. I hope this has helped.
Ed
NC Electronic
Mills, Wyoming
Dec 25, 2007 | Toshiba TP50G50 50" Rear Projection...
MY TP50G50 will not power on...
it sounds like you have a defective lamp.Check to see if it is broken
Mar 02, 2007 | Toshiba TP50G50 50" Rear Projection...
Televison & Video Logo
293 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
