I forgot my security code
Hi i might be able to help you but i need your imei number from the back of your phone under the battery then i can use a nokia security calculater to generate your master code.
The problem is if you have entered the wrong code more than three times then the phone is hard locked and can only be unlocked using special software and leads.
This can be done at a phone shop for a small fee.
Let me know then i can assist you further ok
The factory default security code is 12345. If you entered a wrong code 3 or more consecutive times, the phone may switch to a "sleep mode" and ill not accept any entries for the nxt 15 mins. Pls power the phone off , then back on, and let it sit idle/untouched for 15 mins, then try again. If the security code still does not work. Contact the manufacturer.
Note: If you've already set up a security code but you forgot it. Contact the manufacturer directly.
Hi
The default Security code is 12345.
If you changed it and
forgot the security code please contacts your device dealer. They will provide
you the default security code so that you can use your phone.
This security lock
prevents thieves from being able to make use of stolen handsets that is why it
can only be unlocked by authorized device dealers.
Thank You
