Question about Packard Bell Computers & Internet
Packard Bell Slimview 527
Need to know what the pins do on the 6 pin mini din socket ON THE BASE of the Slimview 527 monitor.
SOURCE:
SOURCE: QK-DVDM1 need mini din 9 pin monitor only
I also have a monitor for a qwestar dvd player. email me at [email protected]
Posted on Oct 01, 2007
  • 198 Answers
SOURCE: Blue grid screen on my pc monitor
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
chinna_1977
  • 65 Answers
SOURCE: LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Posted on Nov 17, 2008
SOURCE: Power Pin-out?
I have built an adapter cable which allows to use monitor with the power supply of an external hard drive. The image below contains the pin-out for the power connector of the L50A as well as the wiring scheme for the adapter cable.
For users in Germany, here is the list of complete part list with prices:
  1. Universal Power Supply 12V 2A DC and 5V 2A DC, 13.20€
  2. 6-Pin Mini-DIN Male, 0.71€
  3. 6-Pin Mini-DIN Female, 0,71€
  4. 5m 6-Wire Cable, 2.80€
Have fun, Wolfgang.
Posted on Mar 15, 2009
falter
  • 245 Answers
SOURCE: download driver packard bell ft500
download drivermax and it will scan ur pc and tell u what driver u need for ur pc........its free if u take the free site.....
if no help with this go in touch with dell service department and ask for help
Posted on Jul 03, 2009
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
DID this HDD (Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive) can atach in ASUS K8U-X, Thank you, Nikola
ASUS K8U-X - motherboard - ATX - Socket 754 - ALi M1689
1.0 x PCI - Socket 754,
2.0 x Processor - DIMM 184-pin,
4.0 x AGP 8x,
1.0 x Memory
  • Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - RAID 0 / RAID 1 / JBOD,
    Serial ATA-150 - connector(s): 2 x 40pin IDC
  • Interfaces 1.0 x Keyboard - Floppy interface - RJ-45,
    1.0 x Hi-Speed USB - SPDIF output - 6 pin mini-DIN (PS/2 style),
    4.0 x Network - Generic - 34 pin IDC,
    1.0 x Audio - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1.0 x Audio - Ethernet 10Base-T/100Base-TX - 9 pin D-Sub (DB-9),
    1.0 x Parallel - Generic - 4 pin USB Type A,
    1.0 x Serial - RS-232 - 6 pin mini-DIN (PS/2 style),
    1.0 x Storage,
    Mouse
  • Power Connectors 20-pin main power connector,
    4-pin ATX12V connector
  • as long as the PSU and motherboards power and lead connections are the same as the hard drive
    hope this helps
    May 10, 2011 | ASUS K8U-X Motherboard
    I have a D102GGC2 motherboard with intel pentium 4 processor 524 , LGA775 Pkg 3.06GHz,.So please tell me about related drivers and chipset and how to download from intel site ?
    Link for download of drivers etc. is at the bottom. Choose Operating system, etc and what you need (drivers, software, etc.).
    I don't know if it will come to you as a hyperlink or not. If not you will have to copy and paste or type in address bar as one long string.
    Manufacturer:
    Intel
    Part Number:
    BOXD102GGC2
    General
    Product Type
    Motherboard
    Form Factor
    Micro ATX
    Width
    9.8 in
    Depth
    8.6 in
    Compatible Processors
    Celeron D ,
    Pentium 4 ,
    Pentium D
    Processor Socket
    LGA775 Socket
    Multi-Core Support
    Dual-Core
    Chipset Type
    ATI Radeon Xpress 200 / AMD IXP 450
    Max Bus Speed
    800 MHz
    Storage Controller
    ATA-133,
    Serial ATA-150
    Power Connectors
    4-pin ATX12V connector,
    24-pin main power connector
    Processor
    Installed Qty (Max Supported)
    0 ( 1 )
    Memory
    Supported RAM Technology
    DDR2 SDRAM
    RAM Installed ( Max )
    0 MB / 2 GB (max)
    Supported RAM Speed
    PC2-3200,
    PC2-4300
    RAM Features
    Dual channel memory architecture
    Video
    Graphics Controller
    ATI Radeon X300 Shared video memory (UMA)
    Audio
    Audio Output
    Sound card
    Audio Codec
    Realtek ALC861
    Compliant Standards
    High Definition Audio
    Telecom / Networking
    Networking
    Network adapter - Realtek RTL8101L - Ethernet,
    - Fast Ethernet
    Features
    BIOS Features
    ACPI support,
    SMBIOS support,
    Rapid BIOS boot
    Hardware Monitoring
    System voltage,
    CPU fan tachometer,
    Chassis fan tachometer
    Sleep / Wake Up
    Mouse wake up,
    Keyboard wake up,
    Wake on USB port,
    Wake on LAN (WOL),
    Wake on PCI device,
    Suspend to RAM (STR)
    Expansion / Connectivity
    Expansion Slots Total (Free)
    1 Processor - LGA775 Socket,
    2 Memory ( 1.8 V ) - DIMM 240-pin,
    1 PCI Express x16,
    1 PCI Express x1,
    2 PCI
    Storage Interfaces
    Serial ATA-150 - connector(s): 4 x 7pin Serial ATA - 4 device(s),
    ATA-133 - connector(s): 2 x 40pin IDC - 4 device(s)
    Interfaces
    4 x Hi-Speed USB - 4 pin USB Type A,
    1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1 x Serial - RS-232 - 9 pin D-Sub (DB-9),
    1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
    1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
    1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45,
    1 x Display / video - VGA - 15 pin HD D-Sub (HD-15),
    1 x Storage - Floppy interface - 34 pin IDC,
    1 x Audio - Line-in - Mini-phone stereo 3.5 mm,
    1 x Audio - Line-out - Mini-phone stereo 3.5 mm,
    1 x Microphone - Input - Mini-phone 3.5 mm
    http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D102GGC2
    Hope this helps.
    Nov 27, 2010 | Intel D102GGC2 Motherboard
    AC / DC power adapter for Packard Bell SLIMVIEW
    Here is the replacement from an UK seller.
    Part number is 6860870000 , put this number in google to get the part in your area.
    Aug 27, 2009 | Computers & Internet
    Does my dell dimension 2350 have a dvi port?
    No, it does not.
    Check the specs of your desktop PC here:
    Ports and Connectors
    Externally accessible:
    Serial
    9-pin connector; 16550C-compatible
    Parallel
    25-hole connector (bidirectional)
    Video
    15-hole connector
    Keyboard
    6-pin mini-DIN connector
    Mouse
    USB
    two front-panel and four back-panel USB 2.0–compliant connectors
    Network
    RJ-45 connector
    Audio
    three back miniature connectors for line-in, line-out, and microphone
    Headphone
    one front miniature connector for line-out
    Serial
    Parallel
    Video
    15-hole connector
    Keyboard
    Mouse
    USB
    Network
    RJ-45 connector
    Audio
    Headphone
    http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
    Jul 26, 2009 | Dell Dimension 2350 PC Desktop
    Power Pin-out?
    Have fun, Wolfgang.
    Nov 27, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
    What are the pin conections for external usb on an asus a7v400-mx board
    USB mouse/keyboard to 5-Pin DIN or 6-Pin Mini-DIN adaptor USB Function 5 Pin DIN 6 Pin ps/2
    Pin 1 +5V Pin 5 Pin 4
    Pin 2 -Data Pin 2 Pin 1
    Pin 3 +Data/clock Pin 1 Pin 5
    Pin 4 Ground Pin 4 Pin 3
    shield shield shield
    Apr 16, 2008 | Computers & Internet
    i just happen to own a monitor for a qwestar dvd player. for more info contact me at [email protected]
    Apr 12, 2007 | Qwestar MVP360 Car DVD Player
    Computers & Internet Logo
    270 people viewed this question
    Top Packard Bell Computers & Internet Experts
    Ekse
    Steve Allison
    Steve Allison
    Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
