Garage door only opens a foot from ground
My garage door only opens about a foot from the ground and stops. Press the botton againa nd it goes down, but again will only open a foot. Does the same thing with both remotes and main controller. This never happened before until I wanted to open the garage door just enough to get air inside so I pressed the botton and waited until the door was slightly opened and then I pressed the button and it stopped. Now that is as far as it will open.
Any ideas?
  • 138 Answers
Its due to the gear stucked problem! you should get it repaired by the mechanic! its not any other remote control problem.
Posted on Dec 08, 2007
We just replaced the "trolley" component of the opener, now when we open the garage door it opens about a foot, then stops like its hung on something... it will go back down. If i help it pass the hun
Check your manual and re-program the up/stop and down/stop position. Also make sure the new trolly is in it's proper position.(in the closed position) Hope this helps
Oct 02, 2012 | Chamberlain 3/4-HP Power Drive Chain Drive...
My liftmaster HBW 1573 no longer operates the garage door
Try the programation with the central control of de wall
hold light boton then press de open botton (dont un unpress the light botton. Then put the control about 2 inch of the main control until its open or close the garage door.
Let me now if it work.
regards
Aug 24, 2012 | Sears Craftsman LiftMaster Chamberlain...
Once the garage door reaches about a foot off of the ground it stops and opens again everytime. It's not the safety laser guide. How do i fix it
Release the door from the opener and operate by hand. Does it bind or get hard to move near the point where it reverses? Increase the down force just a bit.
Sep 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi I have a Chamberlain garage door system. I use the remote to shut the door. The door goes down to a foot off the ground and goes back up again. I've tried for over an hour to get it to shut and it won't...
The motor has probably been shut off by the thermal protector. Wait 15 to 20 minutes and it will reset itself.
If when the door reverses and goes back up, the main light flashes 10 times it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Feb 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Worked great the past 2 years. Now, garage door
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door goes up about a foot and stops
The sensors have nothing to do with your door opening. First thing to check are the door springs. One may be broken. Next remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped.
Jun 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door bucks like a bronco
You have a door problem. The reason the door is reversing to the open position is because when it bucks the safety senses something wrong. Release the door from the opener and operate it by hand. You should find something.
Jun 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open or close garage door; inside button flashes
What has happened is that you electric eyes are blocked or have gone out. The eyes are at the garage door about a foot of the ground on both sides. There should be a red or green light on one of them. If not some thing is blocking the beam that goes across the door. It is a safety beam so kids can nt get hurt when the door is coming down. If the beam is broke the door will go back up.
Jan 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Computers & Internet Logo
115 people viewed this question
Alun Cox
David Payne
David Payne
