Question about Sony KP-53HS10 TV
HELP ME PICTURE CUTS OUT BUT I STILL HAVE SOUND
  • mrebots Nov 22, 2008
    cant find the replacement transformer online anywhere!!! help!!
    Novelist:
    Champion:
  • 232 Answers
If your not proficient with a meter and soldering equipment pass on repairing this set. If your ok with it replace these 3 parts, very common failure in your model set
Q8007 part# 2SC3997
Q8008 Sony part # only 872902430
Flyback Transformer part # 1453328521 this is an upgraded part# for this high failure rate transformer. Good luck
Posted on Nov 29, 2007
  • Larry Eastman
    Larry Eastman Dec 18, 2007
    I give you the answer and you rate me inappropriate?????
RCA Model M50WH187 DLP TV - lamp cuts out
The lamp ballast supplies power for the lamp, and it is probably going out. You can probably find one on eBay or ShopJimmy for under $100. It looks like a little box and it will be near the lamp.
May 01, 2017 | RCA Scenium M50WH187 50" HDTV
Tv cuts off and on no picture or sound
Most TV shut downs like this are HEAT related.Try increased cooling with a fan blowing into it to test this on yours.If it works leave the fan running or repair with a nice little but strong computer fan placed behind the unit..
Aug 17, 2009 | LG 32LG30 32 in. LCD HDTV
Lg 42lb1dr tv cuts off no picture or sound. gray screen.
There are 4 capacitors on the power supply board that need to be replace. They are in the same area, same color, look for bulged caps.
Jul 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Sound but no picture and then tv turns off..
Your symptom is that you have no picture but you have sound. And then the sound cuts out.
Sony Televisions have a circuit that blanks the video when there is a problem generating a picture. There may be something damaged in the video circuit, or in the video drivers on the CRT boards. Worst case scenario, you may have bad CRT’s in the set.
No matter which is the case, I would recommend that the set be looked at by a qualified technician.
This person could run some checks and lead you to a repair.
I could not recommend that you repair the set yourself.
There is a high risk of electrical shock when dealing with picture tubes and projection sets, as they have tubes that will hold a charge like a capacitor. This charge is around 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this Solution with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 20, 2009 | Sony KP-46WT520 46" Rear Projection...
IS-LCDTV32 32 Picture Blanks out but sound remains.
the dm chip on the mother board has malfunctioned and needs replacing.
Aug 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Panasonic SC-PT850w sound cuts out
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
Apr 27, 2008 | Panasonic Home Theater System System
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Sony KP-53HS10 TV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
