Question about Sony VAIO Digital Studio PCV-RX550 PC Desktop
Upgrade beyond limits
I want to upgrade my sdram to 1 gig, is that possible, here are my system specs
Proccessor Manufacturer Intel
Processor Class Pentium 4
Processor Speed 1.5 GHz
Cache Size 256 KB
Installed Memory 256 MB
Maximum Memory 512 MB
Memory Technology SDRAM
Maximum Memory Module Max 256 MB module
Number of Installed Processors 1
Maximum Number of Processors 1
Bus Speed 400 MHz
  • gibby1234 Nov 29, 2007
    Thanks for the help, but that only tells me what i already know, that my systems max is 512 mb sdram, i want to throw 1 gig sdram in, and am not sure if that will do anything.
  • 4,102 Answers
If you goto this link it will tell you what you can put into your comp you can only put in the maximum it tell you the link is http://www.crucial.com this will scan your computer and tell you everything about it and anything you can put in it.
It will also tell you everythin that is compatible hope this helps you let me know how you get on ok
Posted on Nov 29, 2007
  • paul proctor Nov 29, 2007
    Hi your systme will get loads of errors and will freeze up alot if you put more ram in than what it can take i have done this myself i didnt know what my maximum was so brought more ram and put it in.
    I got loads of problems then yes it was quicker but kept getting loads of error message and comp completely shut down everytime it was on i kept getting severe error warnings kept freezing up so called someone out thinking i needed to change some settings like turning off the error reports but even doing this didnt help just kept freezing every 5 minutes and shutting down their is nothing you can do to add more ram the only sollution is buy onother board.
    I tried everything to get it to work but was then given that link i gave you and was told it wont work if you go over thse limits sorry i couldnt be any more help but i have been through this with my own comp.
    Had to take out the extra ram and just run it at the max
SOURCE:
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Want to upgrade my HP TouchSmart IQ504 Desktop PC 2.0GHz processor for a 3.1 ghz ?
First, have you ever changed/upgraded a CPU? It take quite a bit of research to upgrage. If you look at this spec of the Mobo your options are very limited, The Mobo only supports 2 different type Processors, 1, Core 2 Duo (Merom); http://ark.intel.com/products/codename/2683/Merom , 2 Core 2 Duo (Penryn): http://en.wikipedia.org/wiki/Penryn_(microprocessor) If you have a 64bit OS consider a memory upgrade, if you haven't already. More info : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01481519&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3752240#N298
Dec 20, 2012 | HP ALL-IN-ONE HP TouchSmart IQ504 PC -...
Installing new cpu on a emachine
According to the specs I have Serena, the eMachines eTower 633i Desktop PC, uses a TriGem Cognac motherboard.
[TriGem is the manufacturer, Cognac is the model.
Note it is Not the TriGem Cognac+ ]
http://www.motherboards.org/mobot/motherboards_d/Trigem/Cognac/
Specifications. (You can click on the photo to enlarge)
PDF motherboard manual,
http://www.elhvb.com/mboards/TriGem/manuals/index.html
Click on - Cognac - in the left side of the list.
Going back to the Motherboards.org page;
(Nothing like upside down photo information, and the motherboard is turned 90 degrees to the Right, to how it actually sits in your computer case )
The processor socket is a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
Used for Intel Pentium III processors, and intel 'Celey' processors.
(Excuse me......Celeron.
An Intel Pentium III processor has TWICE the L2 cache, that a comparable Intel Celeron has.
The cache for a Processor is a small memory area for the Processor.
It is the First memory the Processor accesses.
The Ram Memory is second, and the Harddrive is third.
More cache for a Processor makes it more faster )
The motherboard chipset is an Intel 810.
The Northbridge chip of the motherboard chipset, is an Intel 82810.
The Southbridge chip is an Intel 82801AA, or an Intel 82801AB.
(Intel ICH, or Intel ICH0 )
Looking at the chart, and reading across, you can see what the Intel 810 motherboard chipset supports;
1) Processors: Intel Celeron, or Intel Pentium II, or Intel Pentium III.
2) Processor Front Side Bus: (FSB) 66MegaHertz, or 100MHz.
3) SDR Sdram ram memory at 100Megahertz.
[Single Data Rate Sdram is often just referred to as Sdram.
Erroneous.
Double Data Rate Sdram is also Sdram (DDR Sdram)
Synchronous Dynamic Random Access Memory
So is DDR2 Sdram, and DDR3 Sdram ]
Also referred to as PC100.
So when looking for a CPU you look for;
1) Fits in a Socket 370 processor socket.
Yep. The best is going to be an Intel Pentium III.
2) Has a FSB of 100MHz.
Hmmm,............
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down.
Pentium III 1100.
Maximum frequency rate ('Speed') is 1.1GHz (1100MHz)
Front Side Bus = 100MHz
Uses a Socket 370 processor socket.
Part Number = RB80526PY005256
sSpec Number = SL5QW
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Coppermine%29.html
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201100%20-%20RB80526PY005256%20%28BX80526F1100256%29.html
In the top header -
Specifications / Pictures (1) / CPU ID (1) / Comments (1),
click on Pictures (1)
You can click on the photo to enlarge.
256MegaByte of L2 cache. (256MB)
A comparable Celeron would have 128MB of L2 cache.
http://www.recycledgoods.com/products/Intel-SL5QW-PIII-Processor-1100-256-100-1.75V.html
http://www.impactcomputers.com/sl5qw.html
[ Don't forget to follow Anti-Static Precautions.
Clean the bottom of the Heatsink THOROUGHLY, and the top of the Processor if it needs it. (I always do anyway)
PROPERLY apply fresh, new Thermal Paste.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 26, 2012 | E-Machines etower 633is PC Desktop
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
UpGrade
download cpuz it will tell your specs
Oct 18, 2008 | E-Machines eMachines Desktop PC
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
Computers & Internet Logo
134 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
