1999 RCA 62 inch tv
When I plug the cable line into the back of the tv it does not seem to be picking up the cable. My son even pluged his playstation in and it would not come up It was working fine one day then the next time we turned it on it wouldnt do nothing Thanks for any suggestions Lesa
    Genius:
  • 1,030 Answers
Does the picture come up..what is known as a raster(LIGHT) up. does it have sound.
Posted on Dec 07, 2007
My rca tv will not pick up signal and its pluged into the cable input, just got these tv and just wondering if someone could help me
I am assuming it is a new TV. You probably need a cable box. I have no idea who your cable provider is or if it is coming from another source. You also have to program the TV for the correct input.
Nov 18, 2014 | RCA Televison & Video
RCA 52 inch fuzzy screen no buttons work no sound cable doesnt work on it just fuzz
First is you removed power by unplugging the surge protector---this may have confused the micro in the set.
Unplug the set itself (with it turned off) for a while and plug it back to see--sounds like this is your problem to me. Usually in this case only the on/off button on the set works.
Mar 27, 2012 | RCA HD52W56 52" Rear Projection HDTV
Coby DVD765 Theater System and can't control the TV volume through it...I saw the previous post...We have it in our bedroom and rarely watch DVDs in there. Could I plug my RCA audio cables into some of...
The connections will have to go directly into your tv set. On your tv, you should have 3 connnecting points. Red, White and Yellow. On your Theatre system amplifier you should have audio outputs like CD, AUX, etc. Pick one of these outputs and connect to your Red and White RCA on the tv set. Next, connect the DVD player's audio to dvd on your amplifier under the DVD connection. Your VIDEO (yellow) Cable should still go to your tv directly from the DVD player. Now, if you want to listen to the TV channels throug the system, simply select the channel that you pluged the TV audio into. Hope this helps.
Jun 11, 2010 | Coby DVD765 Theater System
No image when switched on
are you plugged in with hdmi or rca (red white yellow) if you hold down the power button til it flashes a bunch then it resets the PS3 to default rca connection you then have to plug in the rca cables that came with the ps3 adjust the setting with both rca and hdmi pluged in then unplug the rca.
Oct 23, 2009 | Sony Playstation 3 (PS3) Console
Vertical blue line in display PS3
Alright, I do believe i have a solution. But i need to know the brand of TV you own, how old it is, and If your using an adapter, or the regular "Yellow, Red and White" cords.
Nov 29, 2007 | Sony Playstation 3 (PS3) Console
Visible bands moving up the TV
The bands are caused by unsheilded power cables that are near the
set. sometimes your tv cable or antenae cable is near a power
source and it is picking up unsheilded EM signals. Remove all
power sources near your tv and tv cable.
Nov 09, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Technical help
You need an audio y cable - That is a cable with a headphone jack (to plug into the speaker/line out jack on the laptop) and on the other end 2 rca jacks (they need to be plugged into the left and right audio inputs on your tv but make sure it is the same inputs that work with the s-video cable) That should get you sound on your tv. You can get 1 here: http://www.newegg.com/Product/Product.aspx?Item=N82E16812196019 Or pick 1 up at your local $1 store. Or if you have an old pair of headphones, rca jacks and wire you can even make one.
Sep 17, 2007 | Televison & Video
RCA F32649 32# TV Troubleshooting Forum
this is an old case and Im sure you have a new TV by now. The problem is the tuner. The grounds are cold and need to be re-heated. The tuner is the little box your cable plugs into. Open the back and you will see where it is soldered to the main board. Heat them back up with a little solder should be three points. while you are in there look around and see if you find more. if that doesnt work then you may have to take the case of the tuner off and look inside for more cold solder joints
Nov 25, 2006 | RCA F32649 32" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
