Question about Compaq Evo N610C Notebook
Usb on my notebook don't work
Noting in the back of my notebook don't work.
not resiving or give info if you plug in to it
  • Dion Croes Nov 30, 2007
    i booth it second hand and after a while i went to just the usb and noting was working,i tried more than one device on it and noting work.i ask some fried of mine and they told me that i have to change the back of it
  • 4,102 Answers
Have you tried plugging more than one usb device into the laptop to be sure that it is not the usb device that isnt working and not the laptop also what else dont work.
Have you tried controll panel and letting the laptop search for hardware devices and then it should let you select from a list everything that is installed on the laptop.
Have you had it from new and did any of these ports work before let me know more and i will help as much as i can ok
Posted on Nov 29, 2007
  • paul proctor Nov 30, 2007
    Hi again if you need the usb port replacing this you wont be able to do yourself as will need soldering and installing ob your laptop.
    Have you tried letting the laptop search for extra hardware if you know how to do this you could even plug something into the usb port, then let the laptop search for the hardware itself after it has finished searching it should give you a list of all the hardware it has found check the list and see if the usb port is in the list or look for the device you have got plugged in.
    If it picks up either of these you will need to let the laptop search for software for these devices once it has done this then their should be no problem.
    If the laptop dont pick up either of these and you know that the usb device works then you will need to get the usb port replaced this can be done and shouldnt cost to much to get replaced.
    Doing this yourself is difficult and also if you mess up the solder it can ruin that part of the board and you will never get it to work.
    Is their two ports or just the one?
    Let me know how you get on and ill try and assist you further ok
SOURCE:
Sony vaio VPCF132FX/B usb board
simply try this..go here
https://www.slimwareutilities.com/products.php
download free drivers software
run scan and see if you have bad or wrong usb drivers; or they need to be updated..if so; download drivers..it's very easy
Dec 21, 2012 | Sony VAIO F Series Grey Notebook Computer...
Usb wont work in 2.0
Go into device manager and look at your Universal Controller Bus (USB). Make sure you don't have any that has a Question Mark or Exclamation Point on them. It looks like somewhere you don't have the correct drivers. Are you sure your USB Ports are 2.0?
Mar 25, 2012 | Computers & Internet
My Bd-hp22 Aquos blu-ray pllayer won't play a blu-ray and I think it needs an update but I don't know how... please help
Hello queerdust89,
Go to www.sharpusa.com and look for a software update. Download into a usb and plug the usb into your blu-ray player. There should be a usb port right at the front. Press menu using your blu-ray remote and go to settings. From there go to software update and click enter. If you have a password on your blu-ray then enter it in, if you have not set one then press enter to start checking data in your USB device. Once it detects it, click yes to start the software update. (NOTE: make sure that there is ONLY the software update in the usb, and other folders or files otherwise it will not update). Once you press enter to start updating, give a few minutes for it to update by itself. Once its done, just turn off the blu-ray and take out the usb. Turn it back on and try putting a blu-ray movie in there. I hope this helps, give me your feedback if it does not. Good luck.
- Joe
Sep 01, 2011 | Sharp AQUOS Blu-ray Disc Player
I have LM50-CVXE2 LG laptop after formating no sound and usb port other items not working how to install and also i don't have any drivers rgds sameer
YOU NEED TO DOWN LOAD THE UTILITY SOFTWARE AND THE DRIVERS FOR YOUR NOTEBOOK. THEY SHOULD BE FOR THE WIN YOU HAVE INSTALLED. HTE LINK BELOW MIGHT HELP YOU.
http://www.notebook-driver.com/lg/lg-notebook-lm40lm50-driver/
REGARDS.
PLZ. DON'T FORGET TO RATE THIS COMMENT
Jul 07, 2011 | LG X-Note LM50 Notebook
It is a Seagate GoFlex 2 terrabyte external connected through usb. I have dropped it several times and plugged it back in and it has worked. This last time it did not work when I plugged it back in. It...
I don't think so you have described properly your problem.
1. USB cable to Casing its completely a USB Device/Drive so where you plugged it?
2. "The Laptop does not see the drive or the USB adapter when its plugged in" you mean BIOS?
3. Windows 7 Pop Up Autoplay window what opens when you try to open it?
May 15, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I have an older(much) 2400p flatbed scanner. Our computer doesnt have the appropriate plug in for the scanner, which has a db25 female(to the pc) plug. I cant seem to find any info on whether the adapter...
This is a PARALLEL scanner and most of the much newer computers don always have these.
You can buy adaptors to install in the computer or USB adaptors that convert it to USB but by the time you have paid for one of those you could buy a new one.
Do a GOOLE search for parralell to USB and that will give you an idea of the cost.
Also do a search for parralel cards to get an idea of that route.
Prices vary from country to country which is why I have not given you any figures
Jan 27, 2011 | Visioneer PrimaScan Colorado 2400p Flatbed...
Gateway laptop will not boot up with or without a disk is there anyway to get my info and files off myself
If you have access to another computer you could purchase a hard drive (IDE/SATA) to USB adapter. Remove the hard drive from the Pacific Blue PC Notebook, plug the hard drive into the adapter and then the adapter into a USB port on the other computer. The other computer should find the USB hard drive automatically and give you access to your files.
This of course will only work if your laptop's hard drive is working. If your laptop won't boot because of a hard drive failure then I'm sorry you're out of luck.
Hope this helps ;)
Jan 27, 2011 | Gateway Laptop with Intel Centrino...
Can you put a cd in this laptop
Need more details, as to laptop model. But if it is a Full sized NOTEBOOK, YES you probably can,,, if it is a "NETBOOK",, then no, you can't. If it is a netbook, you can get a USB powered EXTERNAL CD drive which will connect to a USB port and work that way.
Hope this helps, if you need more info, or have more info to give get back to me,, I CAN solve this problem!!
Jim
Aug 05, 2009 | ASUS Computers & Internet
When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY
Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
May 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Problem with USB ports on PA286A port replicator
is the usb port not detecting any other device or just to your docking station or if you plug any usb device and you get the message like not supported or may have a problem can you do that test and give me some more info
Jan 05, 2008 | HP Compaq nc6220 Notebook
Compaq Evo N610C Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
