Question about Whirlpool Calypso GVW9959K Top Load Washer
Its has power but nothing else
Washer worked fine with no problems till this. The washer will let you pick a cycle then when you press start button nothing happens. Sometimes it works with out a problem others time we have to unplug it for a while then plug back in but no promise it will start. called to get it looked at, they changed the circuit board still haveing the same problem. any ideas?
  • 1 more comment
  • jhalley Nov 29, 2007
    Do you think it could simply be the start button is worn out or just not contacting right?
    So do you think I should call and have them come repair it again?
    The parts are covered, labor is not. so I will Call them and tell them it is still not working correctly. Thanks for all your help. The washer is about 4 years old, I think.
  • 213 Answers
There are 2 boards in there. on the calypso, 9 times out of 10 you have to change both boards at the same time
Posted on Nov 29, 2007
  • chris hooper Nov 29, 2007
    its possible. but the boards have caused more problems with that washer than any other. you can do a google search for calypso problems a see thousands of site about the bad issuses with that washer. theres a class action against whirlpool for that washer too. im not sure if its been settled or not though
    how old is the washer? are you paying for the repairs? or are you under some kid of warranty? if your paying for the repairs id let the company that fixed it know that it still wasnt working and that before you get too much money tied into it you want to return the part they put in and get as much back as possible and get out of it. if it warranty work let them fix it. both of the boards together are around $260 just for that parts. i dont know what they are charging labor
SOURCE:
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Harmony washer power touch screen not work
Make sure all connections are secure. Make sure you have power to the screen and all.
Feb 06, 2014 | Washing Machines
Wfw97hexl0-door is locked and won't unlock or run a cycle just makes a buzzer noise every couple of seconds.
did you try to press the stop button then change the cycle to another then press the power button then press and hold the start button again that works most of the time.
Mar 11, 2013 | Whirlpool Duet WFW97HEXL Lunar Silver...
Kenmore elite HE31 front loader will not start but has power
This seems to be a problem in the start switch diode. If all works fine, but will not push and start and all cycles seem to work when working it manually, this is in the switch timer electronic diode is not working properly. Sometimes a code will not come up, because cycles are still working when manually changing wash cycles. There is seperate switch or electronic trigger that starts the machine, and has probably worn out or not making good contact. If you can unplug machine and then take off panel, trying spraying behind start switch with electronic cleaner to free up any possible dust or dirt. Might get lucky.
Apr 07, 2012 | Kenmore Elite HE5t Washer
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
Sep 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Samsung wf337aa front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 13, 2008 | Samsung WF337AA Front Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
81 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
