Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Mybook essential computer will not recognize the mybook when plugged into the USB
  • 1 more comment
  • CE Leonard Dec 02, 2007
    I have a 320 GB Western Digital "My Book" External Hard Drive. My computer doesn't recognize it anymore. I've tried both the USB and firewire connections. No luck. I tried it on my computer at work and on a laptop. No luck. I've had if just over a year. If anyone has an idea on how to fix it, please let me know.
  • Mr-Andersson Dec 07, 2007
    Well I have the same kind of problem! The external hard drive my book ain´t recognized by the computer. It´s named undified not working properly usb unit!!!! What to do?
  • alvargo Apr 24, 2008
    Running into the same problem trying to install the Mybook to my Dell 8300 desktop. Drive powers up, Blue light comes on steady. Windows prompts for drivers but can't find them. Tested the drive on an older PC and the drive connects fine... WD tech support said not their problem....
Hi guys...
I had kind of the same problem like u...when i plugged it into the usb all i got was a "unknown usb device found"
I opened the external case hoping the hdd was still ok only to find out that the hdd cables had been moved slightly out of position..propably from a fall or a knock I didn't even noticed..
I just pressed them back everything was back to normal..
These sites have info about how to open the external case..
Hope that helps!
Posted on Dec 10, 2007
Change mybook from one pc to another
You have to install the backup software on the new computer. Either download from WD to use what came with the MyBook. Attach the MyBook and find it in My Computer. If it is not there, you have to reboot and find the attached device. After Windows recognized the drive, the backup software will ask you for a new backup but just decline and reactivate the plan (actions/reactivate). That should do it!
Dec 05, 2011 | Western Digital My Book Essential Edition...
Computer not recognizing MyBook when plugged in
Have a look at this article on external hard disk troubleshooting. Could be that you need to delete the USB root hub devices in the Device Manager to force Windows to recognize the device.
Jun 24, 2010 | Western Digital 320GB MyBook External USB...
Trouble shoot
does it say new hardware found on your screen if not check the usb cable for loose connection, try conneting it to a known good usb port.
Feb 17, 2010 | Western Digital 320GB MyBook External USB...
Connected but not detected?
Hi, You need to run updates for your computer. Go to start, program, windows update, run and install all the updates, look especially for any update for hardware, select it and let it install. Leave the My book attached to the computer while searching for updates. Good luck.
Dec 21, 2009 | Western Digital My Book Essential Edition...
Connection problems with my Western Digital MyBook EE 2.0 320 GB.
Go to Programs and Devices and see if your Western Digital MyBook is even listed on your computer.
Jun 28, 2017 | Western Digital My Book Essential Edition...
No driver installed for the device
download testdisk and run to see if a boot sector can be ressurected
Oct 03, 2017 | Western Digital 160GB MyBook Essential...
MyBook -Not booting up
Fixed by turning off USB legacy support in BIOS
Jun 14, 2008 | Western Digital My Book Essential Edition...
Mybook premium edition 500gb malfunction, HELP
you might have a bad drive, espeacially because its not working on any pc.
Mar 02, 2008 | Western Digital My Book Essential Edition...
WD My Book Essential -- Can't find drivers
It should not really need drivers in Win2K or Vista, you might have a problem with your USB drivers. Go into device manager, remove any devices under the USB heading and reboot. All the drivers should reinstall and hopefully your MyBook will come alive again. Otherwise, try the MyBook on a friend's computer, if it doesn't work there then the MyBook may be faulty itself.
Jan 15, 2008 | Western Digital My Book Essential Edition...
MyBook 500gb won't show up?
I have had this problem with several MyBook hard drives. They work fine for a bit and then the windows xp OS fails to recognize them. If they do show up the computer warns me they are not formatted. My solution does not help fix the MyBook as is. However, if you have data you must have on it this may be of help. I simply opened up the MyBook plastic case. It is different for each drive. The Pro/premiums I have found you must remove the rubber packing to get at the latch area. After I removed the bare drive from the holder I used an IDE/SATA adapter kit with external power and plugged directly into a USB port. The drive was recognized immediately and I offloaded the data. The drive actually works better now then when it was in the Mybook holder. I am taking no chances though and have switched to LaCie drives. Hope this helps somewhat.
Nov 09, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
613 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
