Question about E-Machines eMachines Desktop PC
Won't come on
When i turn on my hard drive the fan runs loud and the monitor screen read check pc monitor is fine. what do i do to fix it?
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Need more information .
Posted on Nov 29, 2007
SOURCE:
My dell inspiron 545S won't load. gives me error #25
It' most likely that your hard disk drive is defective. Try to boot from a CD\DVD disc, if it does, you have a problem with your hard drive.
Feb 15, 2013 | Dell Inspiron 545 (884116037743) PC...
Acer aspire m3640 no power light hard drive light on
Check/reseat monitor cables. If the fan and HDD are running, perhaps the power led is out. Check the monitor cable connections. Is the monitor plug into AC? Turned on? Shut down Desktop , unplug, reseat Graphics Card, if applicable, reboot.
Dec 13, 2012 | Computers & Internet
Monitor is OK but when turned on the screen is black with a little square that has a message "Dell, No input signal". How can you repair this.
Monitor is not getting signal - picture from pc. Did this ever work or is this new pc? Is PC running? Does it do more than just blow fans? Like hard drive spinning up etc.. Check your video cable connections. Turn off monitor and pc first. Remove and re plug both ends of the video cable. Look for bent pins in plug ends before re pluging. Try a different cable if possible. If not fixed, you may need a new video card. Is this a pc that was working and suddenly failed? Either the pc is not running, or the video card is failed.
Nov 09, 2010 | Computers & Internet
I have a Sony VGN-FZ240E that will start up and go to the VAIO screen and then it goes to the black screen with a flashing spacer bar. It also makes a loud squeal and a soft clicking noise. Can you help?
With a loud squeal, it is either your hard drive eating itself up or a fan trying to spin. If it sounds like a pretty songbird caught in a blender, it's probably your hard drive. If it sounds like your younger brother trying to make the most annoying sound in the world, it's probably your fan. To check you could blow compressed air into the fan ports to see if it dislodges a lot of dust. I'm guessing that it's your hard drive though because it is accompanied by the clicking which may be your hard drive trying to reset itself, but having a physical problem. Don't worry, after a few minutes it usually fails completely and you won't have to listen to that noise any more. Maybe take the hard drive out and put it in an external case and see if another computer can read it. Or go on Craigslist and find someone to fix it for you for $40.
Jul 24, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Fan makes a lound noise and power button is orange
It sounds as if your power supply is cooked because the cooling fan has been running slow
Only way you can check is to take a panel off and hook a voltmeter into the 12v & 5V supplies on the Hard Drive and the Floppy Drive.
Jun 25, 2009 | Dell OptiPlex GX280 PC Desktop
Computer won`t start
Hello there my friend
There is a easy check, it sometimes MEMORY PROBLEMS, or VIDEO , check your RAMs, and take out one module, if has more than one, and restart the PC, I know you will write me back! :)
tell me!
Open Sky
Sep 19, 2008 | Everex GA3400 Refurbished AMD Desktop...
Not booting
Check your monitor,if it is running fine.Switch off your pc and monitor both.Switch on again.If u are not getting any display on screen ,u may need to repair your monitor.in between press on capslock or numsluck key.If keys are giving lights then 100% it is a monitor problem.
Jul 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
87 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
