Question about Sony CDX-C7000X CD Player
Wiring speakers cables diferent colors fort speakers
    Brigadier General:
  • 6,966 Answers
For a Sony CDX-CD7000X, the connection would be:
and the wirings would be:
The images were cropped from the unit's spec sheet.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 29, 2007
  • Louie  Role
    Louie Role Dec 03, 2007
    Hi again,
    Any development on your concern (wiring for a Sony CDX-CD7000X)?
    Cheers.
SOURCE:
How to connect spekers
If it's your first time in this project, connecting speakers are not simple but you can learn fast. First of all, I don't know the type of speakers you have. Not all speakers are the same, even in sound they're not the same. Some sound superb, others sound just right and many sound like tin cans. Because you have a Kenwood KR-X1000, it looks like you have large speakers. To connect these large speaker you need high quality speaker cables, not cheaper low amp types. Cables for speakers are usually marked with a continuous colored line along one side the cable. This line is an orange color is the cable is 100% copper and is a clear plastic cable (you can see the braided or twisted wire inside), or it could be black plastic with a white or grey colored band on one side of the cable. The colored bands means it's positive side (+). Split the cable ends then splice about half inch and twist the exposed wire. If you have a soldering iron, solder the exposed twisted braids to make it into a single solid wire for easy insertion into the speakers.
Now, I don't know what speakers you have but it doesn't matter, as long as you are aware that there are three types of connections used to connect the wires to the speakers. One type is a snap-on, another type is a squeeze, insert the wire in and let go. This is like a clamp. Another type is the a bolt type with a hole in the shaft of the bolt. The head is usually a plastic but to hold the wire and it is the strongest. Let's say you have the bolt type used by many professional speaker makers and users. You simply unscrew the plastic nut until the hole is open, then insert the wire in the hole then screw the plastic nut back tight. do a light pull test to see if the wire might slip out. Remember that these speaker connectors are colored red and black and the wire with the colored line on sheath is positive, that is it goes into the red connector. Then on the other end of the cable bet some tape or a tie to say this is the left speaker and this is the right speaker, this is the rear speaker and this is the right speaker, so that when you connect them to the Kenwood, you will not have to check which cable goes where.
The same thing goes with the Kenwood wire connection. I am a Pioneer man, I know them well. But I just happen to know that Kenwood and many others are very similar in wire connections because I am close to a store that has these, so, it's easy for me to go there and learn the tricks of trade. However, when I was writing this, it was too late to go down and have a look and the Kenwood X1000. So, I can only say that if you looked behind the machine, you'll find it all easily set and you can't go wrong. The red is positive (+) and black is negative (-). If you have been able to wire the speakers as instructed above, then you are also able to wire the Kenwood amplifier. Split the cables and strip or splice a half inch to expose the stranded wires the twist them and solder to form a solid wire for easy insertion and to stop the little copper wires in the braid from separating themselves from the twisted group. Then insert the colored line of the cable into the positive (red) clamp, clip-on, or screw type connector, whichever your amplifier has. Insert the negative soldered wire into the black clamp, clip-on or screw type connector. Do the same with the others speakers wires, recheck the connections, paying attention to polarities and test. It should work without problems. Cheers.
Dec 15, 2014 | Kenwood KR-X1000
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
I cant remember how to hook up the speakers to the system
Speakers use a cable that consist of 2 insulated wires. The two wires are identified by one or more ways: 1) one wire may be golden colored and the other white or silver colored, 2) the insulation on one of the wires may have a raised ridge, or 3) the insulation on one wire may have some marking along the surface where the other will not
The terminals on speakers and terminals for the speakers on the amplifier will both have a (-) and (+) symbol for each cable (one for each wire). I like to assign the (+) terminal to the golden colored wire or the insulation with the rib or marking on it, and the (-) terminal to the white or silver colored wire or on the smooth or unmarked insulation. It does not matter which wire you assign to which terminal - as long as the (+) and (-) terminals of the speaker connects to the (+) and (-) terminals on the speakers of the amplifier (you should see to it that they do not get crossed so that the (+) of the speaker is connected to (-) terminal for the speakers on the amplifier).
Connect each speaker location to the corresponding speaker terminal on the amplifier (the front right speaker to connect to the front right speaker terminals on the amplifier - continue until all speakers are connected). Failure to connect correctly will make fading front to back and balance left and right work unexpectedly.
I hope this helps and good luck! Please rate my reply. Thank you.
Apr 09, 2011 | Audio Players & Recorders
Color codes do not match my new radio can not get any power to the radio
Do these colors match your truck wire colors? Let me know if not or if you have more questions.
1991 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Oct 16, 2010 | 1991 Ford Ranger Supercab
I miss some cables of the Digital BA735. Which cables I have to purcahse?
You need a set of RCA cables, Red & White, you will need two sets. The Cables, simply wire color to color. You nay also need, some adapters, if you cannot get RCA to Phono Jack, on one end. To make with PC, Output Socket, you need an 3.5mm Phono, Jack, and on the other end, the RCA, for connection to the Speakers
http://www.ehow.com/how_4793807_wire-boston-acoustic-proseries-amp.html
http://www.ehow.com/how_5412465_connect-boston-acoustics-ba-speakers.html
How to wire the speakers at above two links.
http://forums.overclockers.com.au/showthread.php?t=229490
Drivers above.
Apr 09, 2010 | Boston Acoustics BA735 Computer Speakers
I have a 1993 cutless ciera and trying to put in a kenwood radio but the color wires don't match
sometimes that happens but the constent power the on off power and ground should be same but the best way to test speakers is to wire the powers and ground and test the speaker by wire them individually and mark to see wat side and front back
Jul 24, 2009 | Car Audio & Video
I have Ford Econoline 150, year 2001, I'm trying to install my radio, but the wire colors from my van it's diferent from the radio. How can I match the colors?
use a voltage tester and a AA battery  using the voltage tester locate the positive and ground (find ground by continunity from the wire to the body) then through trial and error  take two wires put one to the positive and one to the negative side of the battery and if the speaker makes a humming sound BINGO you found a speaker mark it and attach to according wires from the deck  or you can buy an install transfer kit from and electronics store like radio shack  for about $40.00 - $80.00  good luck
Mar 28, 2009 | Car Audio & Video
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Speakers don't work after getting unplugged once! Light doesn't turn on, etc.
Well it sounds to me like you got them in the wrong plug try a diferent one it wont hurt
Dec 01, 2007 | Dell A215 Computer Speakers
Sony CDX-C7000X CD Player Logo
1,230 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
