Question about Mitsubishi VS-45607 45" Rear Projection Television
How do I replace all 21 Capacitors?
It seems i have the same problems as every one else. My TV must warm up and then no more horizontal lines. I can not afford the repair, so how or were can I find out how to replace these 21 capacitors?
  • Anonymous Dec 31, 2007
    like wise...have the rolling picture when warm up it clears.
    Genius:
  • 1,153 Answers
Read threads here or ctechnicians.com
Posted on Dec 22, 2007
SOURCE:
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
Sony tv 21 inch horizontal output transistor failing frequently
• Power Supply B+ is higher than normal
• Partially shorted Flyback Transformer
• Bad Deflection Yoke
• Too much oscillation on the Jungle IC
• Bad capacitors around the horizontal output transistor
Sep 27, 2012 | Jwin JV-TV9090 21 inch TV
Picture goes to a single horizontal line.
Your problem is due to failure of the vertical scanning circuits in your TV. This is quite common and is caused by aging components. Generally drying out capacitors
You got to be careful not to leave it on too long when the picture collapses, it will burn a permanent line across the screen.
If you are an electronics expert you can fix it if you get a schematic. If not please don't attempt to reapir it yourself since there is high voltage in side the TV.
The problem may get worse with time.
Mar 13, 2010 | Toshiba 32D46 32" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
Since this seems to recover there are 2 possibilities:
1) There are a number of poor solder connections on the main board that are causing enough of a circuit disruption to be detected as a problem. When the set "warms up", this seems to correct itself.
2) There are some defective capacitors in the horizontal circuit that again work sufficiently after warm up to allow the set to function.
If you are comfortable working inside the set and can solder, you should be able to fix this yourself.
Let me know if that is what you would like to do and I'll provide details.
If not, the parts required should not be more than $20. Add in the local labor rate for the total repair cost.
Dan
Jul 02, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
33 inch Panasonic gaoo bought in 95 picture trble
Check for leaky capacitors in the vertical section of the TV or cold solder joints.
I would also check in the power supply.
Good Luck.
Jan 16, 2008 | Televison & Video
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Picture has horizontal lines that move to middle of screen........
Just got this fixed. The problem is the 21 (yes, 21) main capacitors. It'll only get worse if they aren't replaced. The whole screen'll start jumping, multi-hour "warm up" times until you get a clear picture, maybe not even then... it isn't pretty. Just nip it in the bud now, and more power to you if you tackle it yourself. A good repair shop ought to be able to do this for under $400 if you can't.
Nov 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
