Question about Dell E173FP 17" LCD Monitor
Monitor flashes on and off!
The monitor flashes on for a split second showing the startup screen, then goes black. Power button flashes on and off in green. Can you help me ?
  • 5 Answers
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Posted on Dec 06, 2007
SOURCE:
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
I have hp w1907 computer monitor. After window startup my screen go black, the monitor light is blue, so it's on. If I press the the monitor button off then back on.....the screen will show for a second...
x2 test monitor on other pc.
if its ok we fix pC>
if the pc drops the sync lines H/V the monitor goes to sleep mode.
and tells you that.
the old monitors 2004 have timer inside,
does the OSD menu button on front of monitor work
with PC on,? it must.
OSD = on screed display from monitor brain
if yes, makes sure any menu there has the sleep timer off.
if it has it.
this monitor is old older than 2010. and has CCFL backlamps then and older.
so use flash light to see if data is on the screen if yes.
then the CCFL tubes are bad or the HV card inside dead.
yup your your service manaual
advanced OSD page clearly show the power saver clock
turn it off now.
of you cant get the OSD to work find a good PC
plug it in and turn this off below.
sevice manual google is your friend, sometimes.
Sep 11, 2017 | HP f1905 19" Flat Panel LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Dec 10, 2009 | Computers & Internet
I have a VP201m. display flashes at startup and goes black
That's not monitor problem, it's your CPU, probably the Operating System crash!!!( Windows,etc).
Try reinstall it to solve the problem...
Oct 18, 2009 | Computers & Internet
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Oct 29, 2008 | LG Computers & Internet
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
927 people viewed this question
Ekse
Clive
Clive
