Question about Samsung Digimax A7 Digital Camera
Displays "low battery" always
no matter if the batteries are new alkaline or rechargeable, camera shuts down and displays "low battery"-very frustrating! Peggy
  • 15 more comments
  • Brooke32 Dec 22, 2007
    Mine does the same thing - I can maybe get 4-5 pictures taken, then the batteries die. I have 4 rechargeables and always have to have two in my pocket...so I can get another 4-5 pictures. What a pain!!
  • Anonymous Jan 20, 2008
    Have the same problem, bought new batteries the same, got a lithiminm pack the 4 or 5 picture only
  • Anonymous Mar 15, 2008
    I have the same problem, ive bought so many batteries for this camera, as soon as i put tem in and take 1 shot it says i have low battery!! I took it to the store i bought it from, as i bought it 2 years ago, and have hardly used it there is nothing they can do for me. They have suggested i put it into repair and then they will bill me for this, cost unknown!! He said it may be a fault? I have decided to cut my loses and buy another camera, as the repairs can cost anything from £100 >
  • Anonymous Apr 25, 2008
    Same problem---very frustrating
  • Rubarbaru May 11, 2008
    I have the same problem - it worked well for two years and then it started. Every time I put in new batteries, whether rechargeable or not, they don't even last an hour before shutting down due to 'low battery'.  It is very frustrating has rendered the camera unusable.
  • carwash444 Jun 02, 2008
    After 15 minutes of use the batteries show as being low. When put into other equipment they run just fine.
    I have tried a variety of differnt kinds of battteries and nothing helps.
    I suspect a mechanical problem of some sort.
  • tlwarren Oct 21, 2008
    My problem started a month ago, out of no where it started. Brand new hi-capacity digital Duracell.
  • th13 Nov 06, 2008
    same problem and yes I am using energizers 2500 mah.
  • vastvarietie Nov 07, 2008
    I have the same problem. I've bought so many battery!!! I can't even take a picture before it says low battery!!!
  • reinamaria Nov 19, 2008
    I've used the energizer and Duracell lithium batteries and nothing has worked. I even cleaned the inside of the battery holder and nothing has helped.
  • Anonymous Dec 11, 2008
    I would recharge the samsung batteries it came with and it would still display low batteries and shut off. I bought new energizer batteries and fully charged them, but when I put them in the camera the battery symbol stills displays low and the camera shuts off.
  • Anonymous Dec 13, 2008
    As others seem to confirm there is a problem with the camera I feel. Mine just this week was taken out ready for holiday. Showed low battery warning and switched off in 10 seconds. Recharged batteries. Same message and close down. Bought new rechargables with higher rating. Same result. Tried the reserve 'normal' type batteries that charge tester said were fully charged. Same result. Now regret throwing out old rechargables!! Am now going to try the camera shop to see if they have the optional mains lead at hand. That will see if the camera will work at all! Obviously since the camera now costs half of 30 months ago when I bought it it does not justify a repair or return to Samsung for service as will be far more than buying another camera.
    Regards
    Dave
  • Anonymous Jan 18, 2009
    same problem. I kindda guess its related to memory card.While i used original card everything was fine, but after two years upgraded to bigger one, and problems started. Seems i just throw away and stay away from Samsung. Well done lads!!
  • Anonymous Apr 20, 2009
    I have the exactly same problem, however I am using the Energizer 2500mAh rechargable batteries and the camera is still dead. I don't think I will ever buy from Samsung ever again
  • Anonymous Apr 21, 2009
    Camera reads low battery.I take 3-4 shoots the camera shutsdown.real nice!!!!!!!
  • preppyj03 Apr 26, 2009
    I've taken very good care of mine and I'm having the same problem. Fresh batteries out of a pack and it turns on, says "low battery," and shuts off. It went dead on me during my trip to CA - very disheartening. Unfortunately, from what I've been told, it will cost more to fix the problem than just buy a new camera... although nobody seems to know exactly what the problem is... just that there's a problem reading the batteries. I will probably never buy a Samsung again - especially when I compare this problem to the age of the camera and the original price I paid. NOT worth my hard earned money.
  • Anonymous May 13, 2009
    I have the same problem with the camera reading low battery and shutting of before I can take 3 or 4 pictures. I have tried several different types of batteries both disposable and re-chargeable. I wish there was a way to get this problem resolved. I have already replaced this camera due to frustration. I would be interested in fixing it if possible. It was always a nice camera.
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
Posted on Jun 12, 2008
THIS IS NOT A SOLUTION, BUT i FOUND THAT WHEN IT SHUTS OFF JUST SWITCH IT BACK ON AGAIN, YOU CAN TAKE 3 OR 4 MORE THEN SHUTS OFF AGAIN. SWITCH ON AGAIN AND GET A FEW MORE. THIS WAY I GET ALMOST 50 SHOTS PER SET OF BATTERIES, NO MATER THE MAKE. iT'S A GOOD CAMERA, i JUST THINK IT HAS A PROBLEM WITH THE BATTERY LEVEL SENSOR. HOPE THIS HELPS
Posted on Aug 31, 2009
I can't understand why, but my A7 instantly shuts down with fresh alkaline batteries, two of which supply just over three volts. Install NiMh batteries which total only 2.8 volts and the darn thing works. On the other hand, my Olympus uses four batteries and works fine with alkalines, but if I use the rechargeable NiMh batteries it will only take a few pics before the batteries get too low to power it. Very confusing.
Posted on Aug 23, 2009
    Problem Solver:
  • 4 Answers
Make sure the batteries are all the same brand sometimes that helps but it does sound like theres a problem with the camera itself, If the batterys good then it means its not holding a charge maybe take it too a camera expert-depending on what is wrong with it, It might be cheaper to buy a new camera than get it fixed.
Posted on Dec 13, 2007
Put in new batteries. It will turn on and then stay on for about 1 second and then goes black. Help. I have the kodak easy share c183
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to Ni-MH or alkaline batteries.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
May 23, 2014 | Cameras
Camera won't turn on with new batteries
Also make sure all contacts on batteries and in the camera are clean and shiny. Only use dry cloth or cotton swabs if you want to clean contacts.
May 20, 2014 | Discovery Kids 0.3-Megapixel Digital...
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Yashica com
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to NiMH or alkaline batteries.
Jan 03, 2014 | Cameras
Always low battery
These cameras need good batteries. Make sure you either are using quality Alkaline batteries or NiMH rechargeable.
Also check that previous batteries did not leak and damaged terminals
Oct 30, 2013 | Casio Exilim EX-FH20 Digital Camera
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
Canon PowerShot A85
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Oct 26, 2008 | Canon PowerShot A85 Digital Camera
Batter Life
How can I extend my digital camera’s battery life and save money?
Avoid the three main power drains in a digital camera: power cycling, unnecessary flash, and excessive LCD (liquid-crystal display) use. A camera uses power each time it initializes or shuts down, so avoid cycling the camera on and off between shots; you should only turn the camera off when you finish taking pictures.
Also, because it takes energy to use a flash, turn this component off in daylight or high-light areas. Even if your camera doesn’t fire the flash, it takes energy to keep the flash charged.
In addition, the color LCDs used on digital cameras can demand a lot of power (especially if the camera is left on for a prolonged period), so turn off the LCD and use the optical viewfinder rather than the LCD to frame the snapshot. Plus, make sure you only use the LCD sparingly to review your snapshots.
If you haven’t purchased a camera yet, choose one that uses common (low-cost) alkaline batteries rather than the more expensive lithium cells. Most cameras that operate on AA or AAA batteries also will accept rechargeable batteries, which may cost more initially but can easily pay for themselves in the long run. Of course, always refer to a camera’s manual for specific operating suggestions and precautions.
Kindly regards,
micro
Feb 28, 2008 | Samsung Digimax S630 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Samsung Digimax A7 Digital Camera Logo
663 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
