Question about Toshiba TECRA 8000 13.3" TFT LCD Display LQ133X1LH13 P000258380 CD-ROM Drive
Tecra 8000 How do I remove the screen
    Champion:
  • 208 Answers
4 to 6 screrws with small round rubber stopers under them are screws. i would let a pro do it. it can break easy
Posted on Jun 01, 2008
How do i replace a broken laptop screan
Take out Battery
Remove screw covers on monitor
Remove screws
Remove plastic Bessel around screen
Remove screws at top screen assembly
Loosen screws at bottom top screen assembly
Remove video cable behind Screen
Remove screws on side of the screen
Remove webcam cable
Remove video connector
Found it on this video:
HP ProBook 4525s Notebook Screen Replacement Procedure
Feb 04, 2014 | HP ProBook Computers & Internet
How to remove screen from HP pavilion dv6 2012ax
it might be just your inverter its inside the lower part of the screen
it plugs in and lights up the back light its cheap but you need to take apart the screen bezel and if you change inverter change the cable too
these are not expensive parts its just doing it right and maybe not fix it but a cheaper way to isolate the problem
Mar 18, 2013 | HP Pavilion Computers & Internet
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
How to change out a broken lcd screen on an aspire
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
This is its contents without the pictures:
OK, let’s get inside the display assembly.
First of all, turn off the laptop, unplug AC adapter and remove the battery.
The screen bezel* has four screws hidden under for seals. Two rubber seals on the top of the bezel and two plastic seals on the bottom.
You can remove all four screw seals with a sharp object as it shown on the picture below. Glue removed seals somewhere on the bezel so they don’t get lost.
Remove four screws found under seals.
Start remove the screen bezel with your fingers. Proceed slowly while removing the bezel.
Carefully separate the display cover from the screen and access the LCD cable connector
You’ll have to unplug the LCD cable from the screen.
First, unglue the clear sticky tape securing the connection.
Second, unplug the LCD cable from the connector on the screen.
Here’s how you can remove the LCD screen.
Simply remove four screws securing the LCD screen to the display hinge. Remove four more screws from the other side of the screen.
Now you can remove and replace the LCD screen with a new LCD screen.
Put all the screws back in there places
Dec 31, 2009 | Acer Aspire One PC Notebook
Replace laptop screen
STEP 1.:-Turn off the laptop and remove the battery.There are no screws securing the screen bezel. Start separating the screen bezel from the display cover with your fingers.
STEP 2.:-Continue removing the screen bezel on the top.
STEP 3.:Remove bezel from the hinges.
STEP 4.The screen bezel has been removed.
STEP 5.:Remove six screws securing the LCD screen assembly.
STEP 6.:-Separate LCD screen assembly from the display cover.
STEP 7.:-Place the LCD screen assembly face down on the keyboard. Now you can access the back side of the screen and disconnect cables.
STEP 8.:-Disconnect the video cable connector from the LCD screen controller board.
STEP 9.:-Parts of the video cable could be glued to the screen. Unglue the cable.
STEP 10.:-Disconnect cable from the inverter board.
STEP 11.Remove the LCD screen assembly.If you are replacing the LCD screen you’ll have to transfer mounting brackets from the old screen to a new one.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Does the front panal around the screen of my Mitsubishi VS-50707 come off for cleaning behind it?
Yes, front screen can be removed to clean projection mirror and picture tubes lenses.
Remove speaker grille, pull them to remove.
There are 3 screws at bottom of front screen, remove them. There are few wire harness plugs need to be disconnect to remove completely front screen.
Below exploded view of Mitsubishi VS-50607 will help you to remove front screen to clean inside. Be careful while removing screen.
Oct 23, 2009 | Mitsubishi Televison & Video
Leak at bottom of water expansion tank on 2001 s-type se
SECTION 303-03: Engine Cooling 2001 Lincoln LS Workshop Manual REMOVAL AND INSTALLATION Degas Bottle Removal and Installation
  1. Drain the engine cooling system. For additional information, refer to Cooling System Draining, Filling And Bleeding in this section.
  1. Remove the cowl vent screen. For additional information, refer to Section 501-02 .
Cowl Vent Screen Removal
NOTE: To remove the left side cowl vent screen, the right cowl vent screen must be removed first. Follow the entire cowl vent screen procedure.
Right Side Only
  1. NOTE: The fasteners are reuseable.
    Remove the right side of the cowl vent screen.
    1. Remove the two-part pin-type retainers and separate the Velcro ® attachment of the rubber hinge cover to the rear outboard corner of the cowl vent screen.
    1. Pull up on the cowl vent screen to release the lower clips.
Entire Cowl Vent Screen
  1. Remove the two wiper pivot arms.
    1. Remove the two pivot arm nut covers.
    1. Remove the two nuts.
  1. NOTE: Remove the right side first when removing the entire cowl vent screen.
    1. Remove the two-part pin-type retainers and separate the Velcro® attachment of the rubber hinge cover to the rear outboard corner of the cowl vent screen.
    1. Lift up on the cowl vent screen to release the clips.
  1. Disconnect the engine vent hose, and separate the air bleed hose from the degas bottle.
  1. Remove the seven bolts and reposition the cross vehicle support.
  1. Disconnect the degas return hose from the degas return tube.
  1. Remove the two bolts.
  1. Remove the degas bottle from the vehicle.
Apr 12, 2009 | 2001 Jaguar S-Type
REMOVAL OF OLD SCREEN
there should be metal brackets that hold the screen in all the way around the frame. there are usually 2 screws to each bracket..you have to remove all of them to get the screen off
Aug 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Screen removal
Screen Removal
There are two types of screens used on this chassis.
Model 1 - with one piece frame around screen.
1. Remove the front grill cloth assembly and remove four
(4) screws along the bottom of the screen frame.
2. Pull out slightly on the bottom of the screen frame and lift
up and out on the top of the screen frame (and screen) to
remove.
Model 2 - with wood piece securing top of screen.
1. Remove the screw access cover plug from each side (near
top) of the TV and remove one screw from each side.
2. Pull up on the wooden strip and remove.
3. The screen can now be lifted out of the tracks and
removed.
Jan 21, 2008 | Televison & Video
Computers & Internet Logo
418 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
