Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture broken and shrinking
Picture on TV is off centre vertically and is receding in size and out of focus with horizontal lines through it the further down the screen it gets (shaped like an upsidedown triangle). If you knock the side of the tv the full picture will appear, however the horizontal lines continue in the bottom third of the screen.
    Scholar:
  • 137 Answers
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Posted on Dec 09, 2007
Screen picture shrinking . Two wide white horizontal lines
Check vertical output circuits. They control the up and down deflection and when not working you get straight line across front of tube.
Aug 02, 2015 | Televison & Video
Picture shrinks horizontally every few seconds.
You are changing parts in the wrong circuit. The problem is in the vertical circuit. Look for the vertical IC and resolder the pins first. It should be an LA7837 or something similar. Also, check the 100ufd and 47ufd caps in the same circuit.
Keep us posted.
Dan
Jan 19, 2009 | Panasonic CT-20G11 TV
Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Dec 19, 2008 | Televison & Video
Horizontal lines on picture
Can't advise on entering setup but the lines may be due to the maladjustment of the brightness control on the flyback. There will normally be two adjusters, one for focus the other for brightness.
Nov 26, 2008 | Televison & Video
Picture and text extend beyond screen
Your tv needs to be put into service mode with the original Sony remote control and then set the vertical\horizontal size parameter to the correct values and then burn the new settings to memory
Google " sony tv service mode " and you should find the procedure. Good Luck! Write back if you have problems.
barneyluc
Oct 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
One White Horizontal line on black screen
replace the vertical IC problem solved
Dec 31, 2007 | Sanyo DS25390 TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Vertical/horizontal
Since you can bang it to heal it some, try checking for cold solder joints. Caps and IC's next. Careful TV's store up to 3000 K volts unplugged. Enuff to kill.
Sep 10, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
122 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
