Question about KitchenAid KERC507 Electric Kitchen Range
Oven elements dont work / stove top works fine
The oven elements quit working, the control panel shows the oven is on but we get no to little heat out of them. When I put on the convection oven the motor fan runs but again no heat from that element. I have the correct 240 volt power.
  • 3 more comments
  • Anonymous Dec 21, 2007
    The problem was the (20 amp) in line fuse on the red L 2 hot wire (fuse) is covered with black shrink wrap coming from the lower power box.The fuse cost me $2.00 and a bit of troubleshooting. After I talked a service outfit out of a copy of the wiring diagram, I had it troubleshoot in minutes. I had called Kitchen Aid and asked for a copy of the wiring diagram and all they would offer me was we'll set you up with service. The stove/oven works fine. I want to thank you for the feedback.
  • lgray68 Jul 24, 2008
    both elements in oven quit woking.stove top works fine
  • redneckruss Mar 15, 2009
    Where is the fuse located? I cant seem to find it and im having the same issues.
  • Anonymous Mar 20, 2014
    my kenmore stove top is working but the oven quite while we were using it and a spark flew out of the vent when it quite the model number is c970 635121 i have checked both elements and they are fine the timer isn't on or anything either i checked for voltage on the wires that go to the elements and there seems to be voltage there how much is suppose to be there i don't know and i can't find any fuses or breakers on the unit?
  • Anonymous Mar 21, 2014
    switch to fan and element don't work
Repair person also shut the power off before replacing the fuse...
Posted on Dec 20, 2007
I just had a repairman fix my Kitchenaid 507KERCYAL0 electric range and oven. The problem was a $4.00 fuse. I didn't see exactly what he did but he accessed the fuse from the rear - had to pull out the range and I think remove a panel. Hopefully this helps and saves you $$. I ended up paying $90 to fix a $4 problem
SOURCE:
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Just baught the stove a little over a year ago and everything works on it except the heating element for the oven quit working one day just like that. i can hear everything in the back clicking like its...
have you checked the continuity of the heating element if there is no continuity then it needs to be replaced,you also need to check the wiring to the element and make sure it is good if all is good on that end then you will need to replace the electronic control.
Nov 12, 2010 | Ovens
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Frigidaire ES400 range - oven will not opperate, range will
Me too. Oven was on, big "pop" and breaker went. After re-setting the breaker (and setting the clock on the range), the stove top works fine, and the controller for the oven seems fine, just that neither the top or bottm elements will heat up in the oven. 240 V is getting to the control module, but it is not sending out any juice to the oven elements.
Any fixes out there?
Mar 30, 2009 | Kitchen Ranges
KitchenAid KERC507 Electric Kitchen Range Logo
991 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
