HDTV Setup I just got a new HD TV and I'm not quite sure how to set it up. Time Warner gave me RCA cables and I think to get the best picture I need HDMI cable.But given this, when I run the cable line into the converter box do I need to run the cable from the out line to the TV and the HDMI cable or just the HDMI cable? I tried setting up with just the RCA cable coming from the converter box but the message on the TV stated weak or no signal.
  • weon Dec 27, 2007
    I cannot get Hi Def function when I use the "hi def" cables from the cable box to the t.v. I have had the box replaced - so I know it is not the cable box. I can only use the co-ax cable from wall to cable box and from cable box to t.v. Hi def function on t.v. does not work. What can I do.
  • Anonymous Jan 30, 2009
    i setup the new HD cable box but the tv keeps saying 'no signal' what is the problem?
SCREEN TURNS BLUE/THEN DARK/ DVD PLAYS WITH PICTURE/.HAS SOUND...HELP. i AM HOOKED UP TO DIRECT TV.
Posted on Jun 30, 2008
  • 179 Answers
It wont hurt to run both to the set, they wont interfere with each other
Posted on Dec 01, 2007
SOURCE:
Got the digital set up box from Time Warner Cable but they did not include hook-up instructions.
If you have an HDTV, you can hookup HDMI cable from set-top-box to the HDTV's HDMI input and select that input on the TV using your remote. If you have analog TV, you can hookup using RCA cables (yellow to yellow, white to white). You could also call Time-Warner for assistance.
May 16, 2011 | Televison & Video
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
I just bought a new plasma tv. I cannot seem to
You Plasma TV is probably an HDTV, which means you need to change the settings on your Wii to HD. Just go to the Wii menu and modify the TV settings. If you don't want to do that, make sure you connect your RCA cables to the non-HD slots on your TV so that the yellow RCA cable is in the yellow slot and not the green HD slot.
Dec 17, 2009 | Nintendo Wii Console
Do i need time warner converter to recieve hdtvor is tv tuner capable of hdtv
The answer is not as easy as you might think.
1. Since you poted this as a Generic tv, i don't know if you have a digital tuner, check you owners manual and see if a digital tuner is included in your set.
2. You need to contact time warner cable and see if they are broadcasing your local chanels in hd, Here where we are in ohio they are but i cannot speak for the time warner cable where you are at.
If you need a more specific answer reply with model and where you live.
Sep 03, 2009 | Vizio Televison & Video
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Cannot see words at the bottom of the screen.
i think you should call them first, time warner, i don't see any problem with your unit.you try evrything and only this time warner is the only problem.they are sending incompatible tv formats.
May 31, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Picture quality for gaming
Match the PS3's output resolution to your TVs (in this case 720p).
Don't sit too close, otherwise you'll start to see individual pixels.
Make sure the HDMI cable is good quality.
As for picture settings, they will very so much according to the viewing conditions that i cannot give you settings that are gauranteed to work for you. But sharpness should always be 0 when dealing with HD content.
If you want to really get the best picture from your TV, try using a THX disc to calibrate it. Luckily these are normally included on Disney PIXAR DVDs, so go find yourself a copy of CARS or something. Follow the instructions of the THX setup, and you should have youself a sweet looking picture in no time.
Hope this Helps.
Apr 28, 2009 | Samsung PS50A457 50 in. Plasma TV
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
353 people viewed this question
Top Televison & Video Experts
Ekse
