Dual XDMR-7700 CD Player Logo
Posted on Nov 28, 2007
Hooking Up Problems
Hey I'm having a problem hooking up my Dual XDMR-7700 in my 97' Ford Ranger I am getting power to it my cd player, it is just that I can't get any sound to the speakers. How do I hook it up without buying a connector set?
  • whitetigerz7 Jan 04, 2009
    I hooked up my 770 with factory wiring harness & put together correct colored wires, no sound on four in car speakers, but the aux jacks output from the player to my amp & rear 10's works fine.
    Please let me know if it's fixable...or am i in the market for another player again. I am inclined to think something is wrong in car or wiring, because if it outputs sound from jacks, it should also from wires from back of player. Thanx.
  • zirconiasoul Apr 10, 2009
    I have the same problem, only with an 89 camry. bought the adapter, wired everything the way it was shown, and the power works, but no sound.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Dec 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1433
Points
You can always remove the factory speakers to check the colors and then find the same colors in the dash, but it's best to buy the adapter so you dont make any mistakes that might cost you.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jun 29, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
924
Points
10
RUN YOUR OWN SPEAKER WIRES OR CHECK WITH A DEALER FOR COLOR CODES ,... WHICH ARE ALSO IN A REPAIR MANUAL
1helpful
3answers
Operating instructions
Dear sir i have located a PDF version of you xdmr 7700, So if you want to email me on [email protected] i will be happy to send it to you, all the very best, Colin.
I just put in a radio in my 88' truck and i have to reprogram my stations every time i start my truck,why is it not holding memory?
Your red memory wire is not hooked up or you switched the red and yellow ignition wire around and your radio stays powered up when you turn off the ignition.
I cant find which onw is the power antenna wire is coming out the cd player
The wire is coming to be the blue with a white stripe for power antenna, if that wire isn't there you can always use the solid blue wire.
How do you check the fuse on my dual car stero
it shud be in the back of ur unit rite where the wires are ,plug th wires off & ur fuse shud be rite there.
No sound to speakers hooked to RCA jacks.
you have the wires mixed up. the positive wire is hooked into the negative, rechech your wiring
2answers
How do i fix the error 02 on my dual cd770 cd player
I have a Sony CDX-GT210. How do I set the time? Donna
Top Dual Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
