Thomson 28wf25ug ,wont come out of standby.
My tv wont come out of standby by remote or pushing on/off button in,,just flashes red a few times,I think the remote needs programming,but Im not sure what the procedure is please can anyone help me.This a uk model also.
Thanks
jamie
  • 3 more comments
  • shytalkin Dec 05, 2007
    we have the thompson diva 28wf and are having the exact same prob as from this morning
  • Anonymous Oct 24, 2008
    same as above - tv will not come out of standby mode - have to switch it on and off at the set.
    Going round and round - what is the use of repeating comments without suggesting a solution???
    Comcast remote will only give the standby mode - how can one get the remote to switch off and switch on the machine (I have to do these things manually at the machine).
  • ron1976 Jan 19, 2009
    yes
My dad has magnavox tv and needs code to get tv on track.
Posted on Sep 11, 2008
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
Tv wont turn on
well first of all if anything happens when you push the button then the button works! I think you should leave this one to a professional technician. There is a circuit problem that will require advanced knowledge.
Jan 04, 2010 | Televison & Video
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
Red LED flashes when turn tv on
Check for poor soldered joints near HOT and vert circuit
Aug 10, 2009 | Televison & Video
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Thomson 44jw642s problem with starting.
Verify capacitor cp150 (2200uF/16V)
JLopes
Oct 26, 2008 | Thomson Televison & Video
Thomson 28WF25UG
the t.v is in protect mode.
what you will need to do is to first check that the horizontal transistor is not short circuited, if so you would need to check whether there are dry joints around the flyback transformer and the horizontal areas, next in line is to check for high b+ ususally disconnecting collector of hori transistor you get an accurate reading of b+. also check the vertical i.c. if all these are ok then the didtal plug in board is the culprit.
Jun 10, 2008 | Quasar SP-3235 32" TV
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
