Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Random purple or clear static
While watching any input, a clear or purple static appears (4"w x 20"h) on
left side of screen lasting 3 sec.Mostly on darker or solid backgrounds, tv is 2 months out of 3 year ext. warranty
  • 4,102 Answers
This is definately a convergance problem you can get someone out to adjust these it is difficult to do yourself and if you got it wrong you might not be able to undo what you did.
But the chances are you will need the convergence ic replacing this will solve your problem and believe me this is a very common fault on the types of tv most the fault i come across with these tv is the ic need replacing unless you are confident with soldering and understand the amount of electric inside a telly i wouldnt advise you do this yourself as the electric inside one of these can and will kill call someone out tell them you need the convergence ic replacing this will solve your problem and also get them to check any resistors as one or a couple of these going can cause the ic to go hope this is some help to you but it is not something you can do unless you know what you are doing let me know what you want to do.
If you are skilled in electrical repair you will need to be able to understand a spec sheet and follow circuit diagrammes and you will also need relevent testing equipment
Posted on Nov 29, 2007
I cant get it to work on full screen
I am having this same problem as this one above (62HM95). The issue I'm having is that it will also not work full screen. I selected the 'Split' option on the remote and the picture on the left is fine... absolutely clean and perfect, with audio. The picture on the right is completely distorted in very strange colors (mostly constant variations of purple), with audio as well. You should note, that the same video information was feed into different imputes to select for the split. In other words, I feed the cable stream into the TV using the component video (Y B R) as well as the coaxial cable and selected both options for the purposes of displaying the same information side-by-side. On screen I selected video option four (4 for color stream HD) and option (0 for cable/antenna). If I highlight either side and select one of them (4 or 0) the screen goes full screen and I see nothing but one solid color of purple. I've researched the purple and they call it 'Electric Purple'. That is all I see... just the solid purple, with the audio. What I have also noticed is that, If toggle between imputes while in the full screen option and come back to either option (4 or 0) the image plays/appears OK for about 2 seconds then goes back to solid purple. I just can't understand why this is happening especially when the on-screen menu displays perfectly fine. I cannot enjoy this TV by only watching half of it in split mode. Besides the multiple replacement bulbs I've had to buy I've completely had it with this TV
May 29, 2012 | Toshiba 62HM95 62" HDTV
Hp 42 plasma tv cptoh 0602 specs all the time and wavy sd video
Mine has done this from day one, appears to be a resolution problem. All I do is go to a HD channel let it tune in and then go back the the SD channel and don't have to worry about it until next time the power has cycled.
Jul 22, 2009 | HP PL4260N 42 in. Plasma HDTV
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
On an LCD TV? Sounds like you've got a bad TCon board.
Jan 19, 2009 | LG 42LC2D 42 in. LCD HDTV
LG screen out
Bad logic board.Always replace this along with y and z sustain boards.On some LG/Zenith sets they come as a replacement part kit.
Jan 10, 2009 | LG 50PX1D 50 in. Plasma Television
Plasma HD TV Picture blue color static
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 02, 2017 | Televison & Video
Sylvania 27" derailed by Emerson universal remote
CHECK YOUR TV MANUAL FOR REMOTE INSTRUCTIONS IF STILL HAVING PROBLEMS CALL EMERSON AND TALK TO THEM ABOUT YOUR PROBLEM
Aug 25, 2008 | Orion STV2763 27" TV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
