Question about Microsoft Office Professional 2007 Full Version for PC
Unable to print from word 2007
I just installed MS Office Enterprise 2007 on my Vista pc, but am unable to print a document from Word 2007. I can print from all other programmes in Office 2007 but not from Word. I have downloaded the latest drivers for my brother printer. Already installed on my pc was MS works word processor, could this be causing a conflict as i can print a word document when using this programme.
I dont just want to delete Works as it was pre installed and if I do this I will only be left with Word 2007 and I wont be able to print using this programme.
Any help would be appreciated.
Regards
Ian
  • 14 more comments
  • ian256 Nov 29, 2007
    Ive tried re installing it twice and always have the same problem,
    Ian
    Thanks will try that later.
    I have found (by complete chance) as I was trying things, that if I open the print dialogue window,(ctrl+p) then click on printer properties to open it and then without altering anything close the window agian the word document will then print. Wierd. I will try your solution later this evening. Thanks Ian
    I tried uninstalling my printer and the problem is still there just as before, but if as before, I open the print dialogue window,(ctrl+p) then click on printer properties to open it and then without altering anything close the window agian and click ok, the word document will then print. This is so frustrating. After clicking ctrl+p if i then click the find printers button the following message pops up..."The active directory domain services is currently unavailable". ould this be a clue to what is happening? Any help would be appreciated.
    Regards
    Ian
  • ian256 Nov 30, 2007
    Yes my printer is set as the default printer. It will now print but only if i open and close the properties box, which is a bit of a pain.
    Ian
    Thanks for trying. If I get any joy later I will post to let you know.
    Ian
  • franco10 Dec 20, 2007
    I have a wireless printer with the same issue. If you use quick print to notes it will print. Though it will add the header and trailer dialogue on the document.
  • ian256 Dec 27, 2007
    Ive still not found a solution to my difficulty, but i am still able to print if I do the steps outlined above. Do these steps work for you?
    Ian
  • ronblake Dec 29, 2007
    Yes, but not the same luck with opening properties - mine won't print regardless.
  • Corbo25 Mar 18, 2008
    Same error message: Active Directory Domain Services unavailable.
    Will print a test page, but not out of office 07.
  • shav12 Apr 07, 2008
    i have the same problem with windows 2007 i have done several pieces of of work but am now unable to print. I will try the solution i have just read, here's hopeing ! !
    sharon
  • Wendy-Lou Apr 24, 2008
    I have had the same problem, ie. able to print to HP OfficeJet G85 network printer by all other applications except Word 2007. Have just re-added the printer and it did not mention that it had another version of the same printer as I would have expected, so assumed the printer had been set up independent from the already existing printer...and now able to print from all apps including Word 2007 - yay!
    However, cannot find any way to delete the previous version of the printer from this computer. Very strange, but by choosing the dodgy printer and selecting Delete Printer, it deletes the new version. So, of course, try deleting the dodgy version again (after it deleted the new version), assuming that it must have linked itself somehow to the new version and now the new version is gone, we should be fine...but the old version refuses to budge and won't even allow access to the Properties for the old version.
    All computers using this printer via the network are running XP Pro SP2, but have either Office 2003 or Office 2007 apps. Only Word 2007 has had a problem - very odd. I should mention that the printer is not actually a network printer. It is, in fact, connected to a client computer and access is shared to others on the network. Maybe this makes a difference, I don't know?
    Hope this helps anybody else in the same boat, and if there's any suggestions for how I can remove the old 'dodgy' printer, they would be appreciated! Thanks
  • Anonymous Sep 07, 2008
    Unable to print from word 2007 while I am able to print from power point.
  • Anonymous Oct 20, 2008
    I have the same problem, and was able to fix it the following way in Windows Vista/ Office 2007:
    1. Go to Control Panel
    2. Set the printer as your default
    3. Click on the printer properties
    4. Under the "Advanced Tab", click on the "Device Tab" button
    5. Click on "Quick Print"
    6. Turn the Quick Print setup on and make sure the 2 boxes are selected
    Problem fixed!
  • Anonymous Nov 20, 2008
    exaxtly as others
  • AffeNeldorf Feb 16, 2009
    I can't print from either Word2007 or Excel2007, but nay documents I download from a pendrive ( word2002, excel2002) or internet. GERD
  • Wendy-Lou May 11, 2010
    Could you please confirm what is meant by a "holding line" in the printer options (properties?) as referred to in Solution 3? Thanks
I had a similar problem. When I set up Vista I created an Administrator account, then set up my everyday user account. After hours of tweaking settings and re-installing printers, I realized that I could print from Office 2007 from my admin account but not from my user account. Of course, the error messages in no way indicated a permissions problem - they indicated I had a printer problem or a driver problem. Anyway, as a test, I granted my everyday account Admin status and now I can print fine. I had to sacrifice some security just to be able to do a simple thing like use the printer. Oh well, maybe "Windows 2057" will fix everything....
Posted on Oct 07, 2009
I had the same problem with my Brother MFC-640. I installed the new driver, but it wouldn't print from Word 2007 and would print from other programs and the Internet. I was the able to fix it the following way in Windows Vista/ Office 2007:
Problem fixed!
Posted on Oct 20, 2008
  • stnormb Aug 02, 2011
    When I go to printer properties, "Advanced Tab" I cannot find a "Device Tab" button
  • 41 Answers
Try re-installing ms 07... if you need more help, contact me at l19bal at hotmail dot com . cheeers.
Posted on Nov 28, 2007
  • 1 more comment
  • iqbal ibrahim Nov 29, 2007
    oh, uninstall your printer and re-install it?
    no, that happens on mine aswell, but my printer works when i press print... have you set your printer as default?
  • iqbal ibrahim Nov 30, 2007
    oh, im sorry but i don't know what next...
If you have Vista operating system, and you connect to printer via USB and After you've downloaded all the necessary drives, and find that Excel printed but not Word, Here is how I fixed my problem: Control Panel; at Hardware&Sound click on Printer; right click on the printer that is your default printer; click PROPERTIES; then click on ADVANCED then choose PRINT DIRECTLY TO THE PRINTER; Apply; Ok; worked for me. goodluck!
Posted on Mar 02, 2010
    New Friend:
  • 19 Answers
Si desea activar Microsoft Office 2013, puede ir a http://www.instructables.com/id/C%C3%B3mo-Reparar-Error-0xC004F074-De-Microsoft-Word/ que tiene una clave de activaci?n . Key es muy barato y es un verdadero compartir experiencias despu?s de comprarlo para you.I han comprado all? por varias veces, la esperanza puede ayudarle.
Posted on Jun 06, 2016
Turn off Turbo Boost on advanced systemcare 4 if you have it, because it disables 'Print Spooler' process which you need for your computer to access your printer properly.
Posted on Oct 10, 2011
I had the same problem but I found the solutio:
In the control panel choose the options from the printer en set it to print directly to the printer whitout the use of the holding line.
Posted on May 01, 2008
I have the same problem as above. I can only print from notes and no other program. I have a brother dcp-115c. I will install office 2003, no problem there.
Cheeeeers
Posted on Apr 02, 2008
    Sergeant:
  • 272 Answers
I have the same problem:
Dell Inspiron 1520
Windows Vista
Word '07
Brother network printer
It seems I can print a few times but then I shut down and log on or switch users or something and Word can't find the printer. I have to reinstall it in Control Panel. Trying to select the printer with the Office Button/Print yields the message:
"The active directory domain services in currently unavailable"
Posted on Dec 27, 2007
2 Suggested Answers
MrARCADIAN
  • 284 Answers
SOURCE: Unable to print from word 2007
you are going to have to UNINSTALL all of office first and even the LOCKED version of word.
The locked version of word will not allow you to print.
Also after uninstalling office and the locked version of words, then you reboot, then reinstall office 2007 ONLY!
do not download the locked version of words.
if you want to try uninstalling the locked version of word first and see if it works, if not you gong to have to uninstall everything that has office!
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Jul 15, 2008
I am unable to install ms office in my new laptop of windows 7 which contains 2010 starter pack.even I tried to install 2007 also.But i am unable to install it...
You must update first your PC before installing the MS Office 2007.
The reason is, there is an update need to install first before you can install MS Office.
Jul 09, 2011 | Microsoft Office Professional 2007 Full...
Ms Office 2007 enterprise
Office Enterprise is a beta(testing) release & Vista does not accept any beta softwares even if it is from Microsoft. You will have to Intall the Pro version since it has been finally released by Microsft. Also Vista does not support cracked softwares. Best solution is to install OpenOfficeOrg which is an open source code and is compatible with MS Office.
Sudeep(sodeep)
Aug 27, 2008 | Microsoft Office Professional 2007 Full...
Jul 05, 2008 | Microsoft Office Professional 2007 Full...
Unable to install ms office 2007, upgrading from Office 2003
please first uninstall all the existing versions of MS Office. Then try to clean temporary files, cache and registry using tools like cCleaner (freely availavle), then install MS Office.
if you want to install only MS Office 2007, no need to install MS office 2003 and upgrade. directly install MS Office 2007.
If you want to keep both, pleas install MS office 2003 first, then MS office 2007, please dont uograde it, rather select Keep both version.
Please make sure that you have admin permission before doing all this and your system is free from any virus.
Thanks
Zulfikar Ali
May 20, 2008 | Microsoft Office Professional 2007 Full...
Disable the print microsoft office 2007 (enterprise edition)
Click the MS Office button, Prepare, and then choose the security option you desire (disable print, for example). This feature is not available in all versions of Word - but it is included in Ultimate, Professional Plus, and Enterprise. If you have another version, this is not in the security options, but if your product is one of these three, you should be able to handle easily as indicated. Thanks for rating FixYa!
May 07, 2008 | Microsoft Office Professional 2007 Full...
WHY Cant I get Microsoft Word to print?
Best solution is you still have FREE tech support for your computer and also your Office Enterprise 2007. Call Microsoft
Dec 04, 2007 | Microsoft Office Professional 2007 Full...
HP LaserJet 1020 Prints a Black Line when at the right side when using Ms Word 2007
First, you need to try update the latest microsoft office patch file from microsoft or you can open the MS Word, go to "HELP" menu select the update MS Word or related. Try the latest patch file first. You also can try windows update and select custom update, see their list have this problem solution or not. Second, you need to go to HP website download latest driver for LJ1020 and suitable use on Vista. Lastly, if still not solve the problem, you need this problem/issue to microsoft, ask their solutions. Kent
Aug 22, 2007 | HP LaserJet 1020 Printer
Microsoft Office Professional 2007 Full Version for PC Logo
17,556 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
