MSI K9N6GM MotherBoard Install
I just installed an MSI K9N6GM motherboard with a barebones kit. I have 2Gig Memory on the board. I have an AMD Athlon 64 3500 CPU which came with the kit and I purchased and installed a heatsink FAN. My CPU temperature is never reaching above 27 degrees. But the computer will suddenly turn off and the power LED blinks.
  • butilities Dec 21, 2007
    what happened if its a faulty connection and cause short circuit?
What happened if its a faulty connection and short-circut?
Posted on Dec 21, 2007
  • 41 Answers
You could have a faulty power supply, or something in the motherboard settings could be set to switch the pc off after so many minutes/hours. or you may have a faulty connection which short-circuits in the motherboard or somewhere in the pc, casuing the pc to switch off as a safety feature. this is NOT what it actually is, this is a SUGGESTION.
Posted on Nov 28, 2007
SOURCE:
I want to install msi n1996 vga drivwe
You can download the video and device drivers from MSI WEB supportsite, select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
Dec 07, 2011 | MSI K9N6PGM2-V Motherboard & AMD Athlon 64...
I cannot install my VGA...? My PC'S is AMD ATHLON
*********** board VGA is N Vidia chip
You You can install your driver from web side
Mar 27, 2010 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
K7VTA3 v6.0 Motherboard - What Faster processor can I install
AMD Athlon XP 3000+(.13u) (512K,333,Socket 462) according to website
Dec 02, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
Chip up grade options!
That
is a socket 754 motherboard. It will support AMD Athlon processors up to Athlon64 3400+. It is a bit long in the tooth by today's standards, and only uses DDR memory, not DDR2. You may get more of a bang for your buck by buying a "barebones" system, which can consist of a motherboard with processor and memory, depending on how much you want in the barebones package.
Typically you use the case, power supply you already have with the new motherboard and processor and ram (memory).
At any rate, if you only want to upgrade your processor, keep in mind that your board only supports up to the Athlon64 3400+. It will support up to DDR 400 ram. You would probably benefit more by buying 2 sticks of 400 DDR ram at 2 gigs each, if you don't have much ram now. If your processor is close to the 3400+, then another processor in that board isn't going to change things much.
Good luck, and write back if you'd like more help.
Sirwriter
Socket754 Supports AMD Athlon64 upto 3400+;
Nov 02, 2009 | Computers & Internet
Can I buy just a motherboard for an hu 61
you can buy replacement motherboards for you HU61 you have to look for a mini itx board. you can check on the net for mini itx boards.
Aug 06, 2009 | AMD FIC Ice Cube HU61 Athlon 64 Small Form...
I have lost my motherboard driver CD( AMD Athlon(tm)xp 2000+ 1.68 GHz,),from where i can download?. plz help?
If your motherboard is ASUS then you can go directly to www.asus.com and search for the k8mv motherboard drivers or
if its a MSI board the go to www.msi.com
May 15, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Memory +cpu upgrade
No to the cpu you selected. Board would not support that cpu. The RAM you selected would probably work but for how long I couldn't say. With prices pretty low right now it would probably be better to purchase a new motherboard, cpu, & RAM. Hope this helps.
Jan 10, 2009 | MSI MS-6367 Athlon XP 266FSB MicroATX...
MOTHERBOARD UPGRADE
1 yes,
2 buy a new board and chip, trust me spend as much as you can and as much memory as you can afford and laugh at the snails pace of your old system
Nov 05, 2007 | MSI KM4M-L Motherboard
Computers & Internet Logo
1,436 people viewed this question
Ekse
Alun Cox
