Question about LG WM0642H Front Load
On high speed spin cycle the entire first floor vibrates, is this normal??
The final spin cycle is high speed and although all of the leveling feet are firmly planted on the floor, the vibration of the machine transfers throughout the entire first floor of my home. Is this typical for these types of washers?
  • UNHAPPY123 Mar 28, 2008
    I own a LG WM0642H front load washing machine and yes, I am experiencing the same problem with vibration during a High Speed Spin. One of the Best Buy tech's performed a floor test and it was determined that the floor did not appear to be the problem. He simply placed a full glass of water on the floor in front of the machine. His contention was that if the water spilled onto the floor during a High Speed Spin, the floor was not solid enough to support and prevent vibration. However, after the test was over, there was not a drop of water on the floor. In fact, the water in the glass did not move during the High Speed Spin. As a result, I am pretty much convinced that the problem is not with the floor but the machine. When I tub spins, I sounds like something is not propertly balanced inside the machine. I have requested LG through Best Buy to have a LG authorized repair service to try to determine what's wrong with the machine. Will keep you posted.
  • tiredofitall Sep 10, 2008
    Yes, I have the same problem. Sears had installed the washer, and altough the problem wasn't too bad, I had them back to check it. The tech said the installers hadn't levelled it properly and did so; he informed me that had I not been "lucky" enough to have paid hundreds of dollars for the protection plan, his visit (to fix, remember, what he said Sears' installers had done incorrectly), would've cost a couple of hundred dollars. Naturally, his efforts resulted in the problem becoming much, much worse. The next tech basically discounted everything I told him--everything that I've written above ('cause, you know, what do we stupid customers know?) and said that today’s front-loaders are too heavy, hold too much laundy and water, and spin too quickly / forcefully; that putting them on pedastals “throws off their centers of gravity” (so Sears shouldn’t sell them or protection plans for them), determined that the machine was "perfectly level" and that there was no mechanical problem (DUH), and that he could “see that the problem was a weak floor,” which was “moving like crazy”—I was unable to see any movement whatsoever. He noted that even “if” the floor is up to code, this state's codes are not good enough (so, again, Sears should not sell washers / pedastals or protection plans to buyers in this state). He advised to me “shore up the floor,” that Sears “unfortunately” couldn’t cancel a warranty because of weak floors, and that now, since my “weak floor” is documented, if I “keep calling, looking for them to make the washer work on the weak floor,” they they WILL cancel the protection plan. (But don't worry: although the charge for this visit would've been another couple of hundred $, since I was "lucky" enough to have that protection plan, it was free!) Worried now about my "weak floor," I too tried the water test, but the water didn't move at all! I then paid $300 for a home inspector, who assured me in writing, which I will share with Sears as soon as I get the energy to deal with their non-customer-oriented "customer service," that my floor was absolutely fine. Further online research convinces me that the 2nd tech was right about one thing: the manufacturers built these things larger and faster and too hold much more weight than, for example, the front-loader I had purchased in 1997--and that's the problem here. It's not that our floors were built too "weak" for the machines; it's that the manufacturers built the machines without regard to wood floors' natural, miniscule movement and weight capabilities; and that the retailers, stuck now with customer calls and complaints, have decided to place the "blame" sqarely back in the customers' laps, rather than owning up to this HUGE design floor and seeking help from the manufacturers themselves. The manufacturers built 'em; the retailers sold 'em; the customers are stuck with 'em. Depending on how desperate you are, you might also want to look Lowe's / Home Depot and / or on the web; a couple of manufacturers are selling pads to put under the washer's feet to slow vibration--I've seen them for between $30 & $40.00.
    Champion:
  • 249 Answers
YES IT IS; SORRY
Posted on Nov 28, 2007
SOURCE:
Brand new electrolux front load washer w/ factory stand violently vibrates during spin cycle. I have adjusted legs and checked level several times to ensure the machine is secure and does not rock, but...
Although you say it's level I would recommend you try my method to make absolutely certain!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 09, 2011 | Electrolux EIFLW55HIW Front Load Washer...
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
4 month old washer is so loud it sounds like someone dropping a trash can to the pavement from 5 feet high
Check to make sure it's level. Number one cause of vibration is not being level. Number two cause is soft floor and what I call "Sympathetic vibration" where the floor shakes a bit and it seems like it's in time with the vibration on the washer. It then magnifies the vibration and makes it worse.
If it's level and on a solid floor, you need to get it serviced under warrenty.
Feb 22, 2010 | GE WSXH208A Front Load Washer
How to keep the floor from vibrating while in spin cycle
Most likely cause of vibration is that the washer isn't leveled. Use a torpedo or carpenters level and adjust the support feet on the washer to get it level. If it still makes the floor vibrate, you may have a soft floor. You could then try putting a piece of 3/4 plywood under the washer to help support the weight.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer in high spin cycle "walks" slightly away from the wall although when I put a level on it it appears to be level. The floor vibrates when it is in this high spin cycle. Feet are not raised very much...
make sure all the pegs are touching the ground. You may have the vibration dampner going out or the weight on the wheel is loose. You can find all that by unscrewing the back of the machine
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Bosh washing machine has excessive vibration according the the level i put on the top of the washer it is level, but still seems to walk accross the floor on the final spin cycle.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
Feb 05, 2010 | Washing Machines
Vibrating only on final spin
no cement is perfectly level so you will need to level it with a spirit level
Jun 11, 2009 | Washing Machines
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
Samsung P1253 washing machine doesn't spin fast leaving clothes wet
I found a solution on another site. At first I didn't think it would work, but it did....
The samsung washer is very sensitve to balance. Although you may feel you have all of the feet tight to the floor....run the spin cycle, as it runs up to the middle speed, watch each foot closely, one of the feet will lift up and down just a tiny bit (or more)
Lift that corner slightly and Tighten that foot. Continue to run the spin and watch the feet, make sure none of them move at all.
Mine immediatly went up to the faster speed and wrang out the clothes like it did the first day i got the machine. Once done, be sure to LOCK the feet with the ring at the top.
good luck!
Jan 12, 2008 | Washing Machines
LG WM0642H Front Load Logo
353 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
