Question about Brother ML-300 Typewriter
How do I get the @ sign?
Rather than the @ sign appearing, I am having the n with the ~ on top.
How do I get my @ sign?
  • Aralacia Nov 29, 2007
    I don't believe this is the issue, because everything else appears to be in english. The @ symbol is the only key (at least so far) that I've encountered any issues with.
    Problem Solver:
  • 19 Answers
Obviously you have a Spanish print wheel installed on an English keyboard machine/setting. Check with a Brother dealer about obtaining an English print wheel.
Posted on Nov 29, 2007
  • John Lavery Nov 29, 2007
    Ok, look out for the symbols ,usually on the left-side of the keyboard, indicating which keyboard is selected. From memory it should be set on the the top one. Good luck,
SOURCE:
How do I access my facebook account? My husband's account comes up instead
If you are seeing your husband's account, you simply need to sign out of his account. Once you have signed out, you can then sign in using your own email address and password.
To sign out click the small down arrow at the top right of any page on Facebook and then click "Log Out" from the menu that appears.
Hope that helps!
Apr 08, 2015 | Facebook Computers & Internet
Each time I attempt to sign in my account Charles Williams name appear on the top ledger
Type your details in the log in box. It is showing the last user who didn't sign out properly.
Feb 21, 2014 | Computers & Internet
I appear offline in yahoo messenger even If I am online
Yahoo! Messenger gives you the option to make your status appear "online", "busy" or "offline." If you want to appear online all the time you must set the messenger to do so, especially if you changed it to a different setting at any point.
1.Sign On
In order to set your instant messenger to "online" you must sign in to your account. You should use your Yahoo! email address and password to sign in to the account. If you want the program to sign you in automatically, you must check these options on the initial sign in box.
2. Settings
Click your name at the top of the "friends" list and change your setting to "available." Available means you are online at your computer and ready to chat.
3. Changes
No changes are made to your status unless you sign off (which you will then appear offline) or if you physically change your setting. It does not change every time you sign off.
I hope you find it very helpful. Thanks
Aug 25, 2011 | CTX Ez Book 700 Notebook
I have a yahoo account. I want to open one for
Go to Yahoo.com
  1. On the right side of the page, towards the top (but below "Web Search"), you probably see "Sign Out". Click on that. (If you don't see a "Sign Out" button, then skip to step 2).
  2. Now, under "Web Search," you should see a "Sign In" button and also "New Here? Sign Up". Click on "Sign Up".
  3. Then just fill out the form that it shows you.
Let us know if that doesn't work!
Jun 04, 2010 | Yahoo Messenger
My imate jama101 is lock it say tap but how many weeks already its still not align how will i stop it and open it,,pls help
most probably it would be showing a + sign in the center just keep on tapping in the center of + sign where ever it appears. At first it appears at the center then at the top left, then at the top right, then at bottom right and finally at left bottom, just keep on tapping at the center of + sign, now continue with the setup
May 26, 2010 | i-mate Jama 101 Smartphone
My mobile imate jamin align screen plz salution
Mar 28, 2010 | i-mate Jama 101 Smartphone
MESSAGES DO NOT SHOW ONLY TOP PROTION
I can log to my yahoo account sing in it become sign in but when I click on yahoo mail only the top portion becom appear and yahoo mail page becom hang
Dec 27, 2009 | Yahoo Mail
Blinking signs
You mail box is full. You need to delete some messages.
Jun 30, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
A warning light appear with my hibrid prius
I have same engine problem. Triangle signal pop up after I try to start my Prius with a still wet air filter to the car . The engine just run for less than 30 sec. and stopped with the triangle signe pop up. I think this sign will pop up whenever the engine detect certain major function failure. For my case, it was due to retricted air supply to the engine. I have tried Lovebytes suggestion and the triangle sign disappeared with a dry clean filter. My Prius is running good now. This warnig sign may have other implications. Once you try this method and sign still come on. You need to have your car check by garage.
Bellow attach is the answer from Lovebites
cc1dd82.jpg Lovebytes
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I had the same problem. I unplugged the relays from the fuse/relay box under the bonnet. (Top left side) and replaced them. The problem disappeared. (2001 Prius 109,000 miles)
Jan 05, 2009 | 2001 Toyota Prius
E sign on the phone
usually E sign appears when you can make only emergency calls from your mobile...it happens when there is no signal from your network
Dec 16, 2008 | Nokia 6233 Cellular Phone
Brother ML-300 Typewriter Logo
173 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
