Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LG LD-14AT2 - Error message about filter
Hi
My dishwasher has the clean filter error O3 up all the time. I have cleaned the filter and this error keeps coming up - what do i do now. Thanks
  • bikash2008 Jan 27, 2008
    The same problem with LG dishwasher LD 14Aw2 model. I have cleaned the filters and checked the drain pipe. No result.
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Posted on Mar 08, 2008
Have a ld-14at2 dishwasher powder not fully dispensing and has a average clean
Had a similar problem and was told that my water temp was not hot enough.
Feb 02, 2011 | LG Dishwashers
Same problem really
with all these error codes but nothing paning out i would recommend replacing the control board inside of the door panel.
Jul 20, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
E1 error, pump spinning but not pumping
Just replaced wash pump unit
Thanks anyway
Ernie
Jun 11, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Nov 25, 2007 | LG 24 in. LD-12BW5 Free-standing...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
303 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
