Question about Samsung C417 Cellular Phone
Phone powers down
My phone cuts out and powers down during calls. The backlight is the first sign that I am going to lose connect. AT&T said that the phone must be turned off periodically to allow updated information to be added when the phone turns back on. I have not heard about anything like this in a while. She compared it to a computer that says you must power down to receive updated information, when in fact new computers simply tell you to go to their site and download the updated information. Please give the scoop as I am tired of getting the run around.
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have the firmware reflash
Posted on Jul 02, 2008
SOURCE:
Ho w do I deal with power cut and flat battery?
As batteries go thru many charge and recharge cycles, they lose their ability to retain full charges. Time to buy a new battery.
Dec 08, 2014 | BT Synergy 6500 Cordless Phone - DECT -...
My sony ericsson zylo. when someone calls me they can hear me but i can't hear them, please help
1. try to switch on the loudspeaker or connect a headset. in case you can hear your partner this way there must be a hardware problem with the phone's smaller speaker. Often as a result of firmly hitting (dropping) the phone.
2. make a test call and try to change the volume during the call. (However, I don't think it can be a problem since power off/on cycle resets the volume to a default value)
Sep 04, 2011 | Sony Ericsson Zylo Cell Phone
My incoming calls are going straight to voicemail
I think it's mostly due to the following: phone is off, lose of connection, bad reception area, network is down. But if none of these are going with your phone then try this. Go to your phone settings> phone or network (depending on menu) and disable 'call forwarding'. It may be set to go to your vm automatically with no delay (0 seconds waiting time). I hope these suggestions work. Regards
Mar 17, 2011 | Cell Phones
Loudspeaker and/or musical player activates unexpectedly while making or receiving a call. Also calls cut down after one or two minutes. This happens occasionally.I have downloaded F-secure mobile security...
update its software with usb cable and internet connection.
go to nokia official web site and download software updater and then connect ur phone with pc or laptop and do as directed in it
it will update your software of your phone ,it may take 15 min
make first that
1:phone is full charged.
2:dont take calls during the process.
3:see that connection of pc to internet & pc to phone cant be disturbed.
Jan 19, 2010 | Nokia N70 Cellular Phone
How can i increase the volume on t303 sony ericsson
During the call press UP on the square button in the centre of the phone(when not on a call this is the default short-cut for your camera)
Jan 15, 2010 | Sony Ericsson T303 Mobile Phone (Shadow...
Jawbone original seems to go into sleep mode. If I have not received a call for a short time, the Jawbone seems to go into sleep mode and I am unable to answer an incoming call with it. I have to answer...
I have a Jawbone and have not experienced those problems. You may have a connection issue with your phone. Maybe the way your blue tooth is set on the phone....power settings?
Oct 03, 2009 | Cell Phones
I keep loseing connection when a phone call comes on house phone
  • call your ISP first to fix the issue on your line problem
  • after that after issue of trouble ticket and resolution of your ISP
  • then your router support
  • thanks
Aug 11, 2009 | Zyxel Prestige 600WH Wireless Router...
The wired keyboard backlight turnes off too quickly
You would need to go into the Setting Menu and find the Backlight or Power setting to lengthen the display and keypad backlight times. Just know that your battery life will decrease the higher the settings especially since it is a VGA screen.
Dec 18, 2008 | HTC Touch Pro Smartphone
Losing connection lately, and no caller ID??
Hello Kimberlynbil,
You actually have two problems here, one can be solved (but it's hard) the other might not be able to be solved at all.
First the hard (cost wise) to solve problem: Caller ID
What you can do is get a wireless phone that works in the 5 GHz range.
Now for the second problem which is why I suggested the solution to the second problem: Router cuts off phone and phone cuts off router.
This occurs because the router (wireless) and the phone wireless are using the same frequency spectrum 2.4 - 2.5 GHz. when the phone tries to communicate with the hand set the router sees this as an interference and ups its power slightly and this drops the phone call on the first ring which consequentially is the ring on which the data for caller id travels. once the phone senses the interference from the router it up is power slightly and then "steps on the router's transmission cutting off your wireless connection to your PC. So the phone and the computer are off line until one of them stops transmitting.
I hope this helps,
Shuttle83
Oct 23, 2008 | Linksys Wireless-G Broadband Router
Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
Feb 18, 2008 | Nokia 6300 Cellular Phone
Samsung C417 Cellular Phone Logo
46 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
